Monster MotorsportEM Tuning
Results 1 to 28 of 28
Thread: Battery dying
    Apr 2007
    297
    Battery dying
    For the 2nd time in a month my S3 has failed to start due to drained battery. The first time I was in a field and had the stereo on for 3 hours straight so no surprises.
    Second time was this morning. I had left the car standing from Tuesday morning till Friday - got in and it wouldnt start. RAC out this morning to jump it with a power pack. It is the original battery to the car.
    Few questions:
    1) When it was started first time it went flat, the independent Green Flag chap put a clamp onto the fuse pack on top of battery - is this okay?
    2 The ABS light has come on once since (last week). I was told this morning this is due to the battery being crap. Could this also be linked with the way it was started last time as he did put it to the ABS fuse strip?
    3) How can I check it is the battery and not the alternator knackered or both?
    There was a thread on here a couple of weeks back where someone picked up a battery for a good price. Done a search and cant find it. Anyone got any tips of where to go? Not paying 100 plus in dealer prices.
    batwad's Avatar
    Jul 2006
    Beds
    841
    Did the Green Flag man remove the clamp? Are you sure it was a clamp and not an ammeter? He may have been checking the current flow to the battery to assess the alternator. Take the car to a garage or decent parts shop like GSF and they'll test the battery.
    03 A3 (8L) TDi quattro Sport, Aluminium Silver with leather, armrest, cruise, xenons and me at the wheel
    Apr 2007
    297
    Sorry, I wasnt clear. Green Flag had a boost Power Pack (as opposed to starting it off another car) to get it going. He put one lead clamp on the battery (right side) and the other end of - I think the minus lead - on the fuse pack on top of the battery to start it. He didnt use a voltmeter or ammeter to check the battery strength - he just started it.
    Would this type of practice damage the ABS in any way as it was the fuse strip he put it to and hence the light or is the light indicative of a knackered battery as per the RAC guy's advice this morning?
    Would Halfrauds be able to check the state of the battery and/or alternator for me? At a cost most likely...
    Apr 2007
    297
    Okay, found place selling Exide batteries for S3 @ £44 all in. Good brand? Good price? Seems cheap.
    Apr 2007
    297
    Or Global with 3 Yr warranty for £44.65 all in. Any preference with you'se guys?
    Maz
    Maz's Avatar
    Moon is made of green cheese
    Jan 2005
    East
    1,008
    I picked up a Bosch Silver Bat for my S3 a few months ago from a local EuroCarParts. I think it cost between 45-50.
    Mineral Grey [
    AMK
    Jan 2007
    Hertfordshire
    520
    I suppose first thing is to check all the lights are off when you turn the car off, including the boot light if you have one?
    Apr 2007
    297
    Yep no probs there. I know nothing about batteries - I'm sure they are all the same at the end of the day?
    Jun 2003
    World of my own
    9,813
    Definately not, Bosch Silver top everytime.
    Mar 2005
    Scotland
    91
    Bosch Silvertop for me too. Very cheap if you have access to Costco. I would doubt the RAC man has damaged anything by connecting the Negative to the fuses on the top of the battery. He could have also used any part of exposed metal under the bonnet if he wanted.
    batwad's Avatar
    Jul 2006
    Beds
    841
    Daft question: have you checked the fuse for ABS to see if it blew?
    Apr 2007
    297
    Yes, fuse no prob. He reckoned it was just down to the battery that it lit up the other week. It was the Green Flag guy who did the weird jump start - RAC bloke this morn was ex VAG technician so I'll go with his explanation. Just wanted to run it past the multitude first. Cheers Y'all.
    PS - what makes the Bosch battery better than the others?
    Apr 2007
    297
    Quote Originally Posted by colinra
    Bosch Silvertop for me too. Very cheap if you have access to Costco... He could have also used any part of exposed metal under the bonnet if he wanted.
    What is Costco?
    And you are right about hooking lead up to any metalic engine block part - it is reccomended in the manual. Its just finding a piece!
    Jan 2007
    29
    To test whether it is the battery or alternator you need a voltmeter, you can pick up a cheap digital one from most car shops.
    Start by testing the voltage across the battery with the engine off it should be reading roughly around 12v, it may still read this if the battery was recently charged i.e. if you've just driven it, but if knackered will drop considerably over the course of a few hours.
    Next test the voltage again this time with the engine running, if it reads the same as before the alternator may be knackered, ideally it should be reading within the region of 14v with the engine on tick-over.
    I had the same problem with my S3 turned out to be the battery, replaced it and all was fine.
    Sorry it's a bit long-winded but hope this helps.
    Apr 2007
    297
    It does help. Halfrauds did a test on just the battery at standstill and it read 12.5v but as you say i had just driven it. i saw a thread on here yesterday (but cant find it now) saying that if the revs increase on startup its the ECU compensating for somewthing (cant remember what) which basically means that something is knackered - but cant remember what! It does this on mine for a couple of mins on start up...
    May 2007
    323
    Quote Originally Posted by Spacecowboy
    I missed this thread aswell.... my S3 on start up revs high for a few minutes and then settles, did anyone have an answer to this ? or the link to the thread ?
    Jan 2007
    Hertfordshire
    520
    Dubplate are you sure yours isnt the choke? Mine starts at over 1k RPM then drops to around 750 - 850 once its warmed up. My car was doing this all the time after I got it out of the garage and nearly stalling but then picking the revs up for a few minutes after dipping the clutch but after a 270 mile motorway drive it was all sorted, I just assumed the battery didnt have enough charge as they had been leaving the ignition on with the stereo on for ages.
    SpaceCowboy, do you have another battery you could drop in it to see? Or take the battery out and undo the little caps on the top of the battery with a 2 pence piece and see if the levels are ok.
    May 2007
    323
    Quote Originally Posted by TheSpaceCowboy
    thats what i thought it was though my Mk3 Golf GTi has never started like this in the 8 years of owning it even on the coldest of days....
    Jan 2007
    Hertfordshire
    520
    Maybe it is a problem then I always assumed mine was because of the choke, but I do get a fairly strong smell of petrol coming through on start up lol plus the fuel gauge takes a dramatic hit on starting in cold weather.
    QUATTRO_REP's Avatar
    Diesel Power!
    Oct 2006
    Manchester
    228
    Quote Originally Posted by Dubplate
    i saw this thread i think if i remember correctly is that if the battery is outputting a low value then it will increase the idle speed to increase the charge to the battery. when its at the correct value it drops off. i think this will also happen if the alternator is slightly faulty as the same output will happen/low voltage.
    thats my understanding on it...i stand to b corrected.
    Audi A3 52 | 1.9TDI Quattro | Chipped 175 BHP | Hids |
    Apr 2007
    297
    All those points EXACTLY the same as me especially the petrol. Hmmmm
    Apr 2007
    297
    This is the thread i was referring to before:
    red battery symbol on dash
    Mar 2005
    Scotland
    91
    Costco is a cash and carry type place they have a few up and down the UK but it is a big american chain. Only problem is you have to be or go with someone who is a member.
    I think the bosch silver for my S3 was about 30-40 quid. They are pretty good for Michelin tyres also.
    My S3 also revs high when first started in the cold. Never been worried about it. I like the smell of raw petrol in the garage ! It settles down after a few minutes.
    Jan 2007
    29
    Just another thought, if it was the alternator would the battery charge warning light not come up on the DIS???
    I'm not sure myself might be worth looking in to though. My S3 has got 130000 miles on it and hasn't needed an alternator yet, I was pretty sure that the high revs on start-up was just the choke. Does it idle high if you start up on a warm engine?
    Apr 2007
    297
    No doesnt do it on a warm engine but then I thought, going by the other threads rationale, that could be cos the battery has been recently charged.
    Apr 2007
    297
    Looking at other posts, it is quite normal for revs to be high (up to 1200 rpm) on start up. Equivilant of the choke kicking and should only last a minute or so so I can discount that.
    I think I will just get battery and Alternator checked rather than tryin to guess what the prob is. Cheers for all your help guys
  28. #27
    Apr 2007
    Wirral
    191
    I thought high idle speed on cold start is to help the cat warm up faster. Thats what I've heard before.
  29. #28
    Apr 2007
    297
    Thats seems to be right too - I was using non tech/mechanical language
