Chris NottAH Fabrications
Results 1 to 8 of 8
    Defratos's Avatar
    You’re Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Question What do these codes mean?
    Hey guys, sorry to bother people with vag com codes again but if someone could direct me to the page where it explains these codes I'd really appreciate it. If you don't know then what would these codes be:
    Address 01: Engine
    Part No: 8N0 906 018 BH
    Component: 1.8L R4/5VT 0001
    Coding: 10710
    Shop #: WSC 01236
    WAUZZZ8L421010038 AUZ7Z0A1997736
    2 Faults Found:
    17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
    P1296 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    I'm thinking the temp code could be down to my coolant being low? I just topped that one up, and got no idea why the voltage would be low as I've recently replaced the battery (and its the first time I see these codes in two years of owning the car)
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    s3ollie's Avatar
    Jan 2007
    749
    im sure the bottom ones from when you changed the battery not sure about the temp one but as its intermittent id clear it and see if it return after a few days/weeks
    Defratos's Avatar
    May 2004
    2,230
    I did clear it at the time of the check, I've driven the car around for a while and it's still there. Now I'm not sure what it could be really.
    Audi S3-BAM
    RS4 B5 380bhp
    Feb 2007
    549
    The bottom one is a low battery , I had the same on mine, new bat sorted it.
    Defratos's Avatar
    May 2004
    2,230
    Yeah the low battery code hasn't come back on again, but the other one is and it's sounds serious
    Audi S3-BAM
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    sounds like a temp sensor giving a dodgy reading, go into the measuring blocks and see if anything looks unusual, ie: something showing -10 degrees when clearly it's warmer than that. might take a bit of common sense to find the culprit
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Oct 2005
    England
    101
    i've seen that voltage low one before when starting with engine immobized.
    Defratos's Avatar
    May 2004
    2,230
    I deleted both faults but a few days later the same one came back up:
    Now where is the Temp & Themostat sensor located? Is it next to the horn by any chance?
    Audi S3-BAM
