Volks AutosAH Fabrications
Results 1 to 10 of 10
    Hotscar's Avatar
    Four Wheel Drifting
    Sep 2005
    West London
    543
    West London Audi
    My car is in for a service at the above today and they have just called me to say they can not complete the service as the sump nut is rounded and wont come out so I need a new sump to the tune of 380 (plus the cost of the service).
    Trouble is, only Audi have ever serviced the car so who's rounded it. Is it worth writing to Audi or would I be wasting my time?
    Advice welcome and thanks in advance!
    Unmolested Ming blue S3 (so it doesn't handle or stop very well), Bose, sunroof and centre armrest but no heated seats - Gone but not forgotten although I am enjoying the new 350CLK!
    PSN - S3hawkster
    May 2007
    323
    Quote Originally Posted by Hotscar
    My car is on for a service at the above today and they have just called me to say they can not complete the service as the sump nut is rounded and wont come out so I need a new sump to the tune of 380 (plus the cost of the service).
    tough one as they could argue that fact that you could of had third party work carried out on it.... personally i would still write to them explaining the situation you have nothing to lose by doing so....
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Just whack some mole grips on it or a helicoil and pull it out. It'll take about 30 seconds.
    Then take it back to complete the service.
    <Insert meaningless geeky specs here>
    Feb 2004
    2,036
    Its balls! They should be able to get the sump plug out even if its totally rounded off! You can get reverse screw drill bits that will destroy the sump plug but get ti out of there.
    Sounds to me that they have knackered the sump by knackering the htreads on it, or are just trying it on! Maybe had the YTS idiot who forgot his "lefty loosy, rightly tighty" saying and stripped the threads!
    Ask them if they cannot undo the thing or cannot do it up? If it is that the oil wont come out, ie cannot reove it, take the car off them and take it to a place wiht an ounce of mecanical savvy!
    if they got it out ask them why a new sump plug wont cure it. ie what other damage did THEY do! !
    Hotscar's Avatar
    Four Wheel Drifting
    Sep 2005
    West London
    543
    Thanks for the comments guys but it's too late for the above, they've done the work. I was just wondering if I could make a case now given the fact Audi are the only company that have ever worked on my car in terms of changing the oil. I had the belts and water pump done by an independent but they wouldn't/didn't go near the sump nut!
    PSN - S3hawkster
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Surely the only time necessary to remove the sump plug is while changing the oil. I'd be pointing the finger at the person who did the last service.
    You say they can't remove the plug because it's rounded. Complete rubbish. As said above a simple helicoil would remove it. then simply use a new sump plug. Quite a bit cheaper than 380+ for a sump.
    My guess is they have damaged something and are now trying to get you to pay for their mistakes. Go down there and take a look at what they have been up to.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    if its the same dealership thats changed your oil everytime then fight your corner, they worked on it last they need to fix it.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Jun 2006
    712
    I would not stand for that, and i certainly wouldnt have authorised for the work to be carried out without them showing me the problem
    complain and get some money back
    Feb 2004
    2,036
    I reckon they stripped the sump threads (easy done if you are a cackhanded moron like dealer techs are!) and are tryin to get you to foot the bill.
    Flipping heck, &#163;380 for a SUMP... what it made of, gold! ? You can get a short block off audit for &#163;1400!
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Yup, a PROPER baffled sump is less than &#163;380.
