EM TuningJMB Retrofits
Results 1 to 21 of 21
    Jun 2007
    advice needed please
    hi all im putting a 2000 Audi s3 engine in the back of my lotus exige, not having had much experience with audi engines im just after some advive on power upgrades and gear boxes,
    i will have to put a 1.8 golf turbo gear box on to the engine to make it two wheel drive (correct if iam wrong ) i have been told these will bolt straight up to the engine.....
    i have fished about for power upgrades and you can re map the s3 engine up to around 300 bhp with out and hassel ?? again this is only things i have been told ( by the people selling them haha )
    and advive much apriciated
    cheers
    andy
    RD350YPVS - Loves 2 stroke oil
    Apr 2007
    Alfreton Derbyshire
    164
    S3 comes as standard with 2 intercoolers, not sure if this will affect your conversion or not?
    Jun 2007
    i was thinking about either one big one or one on either side were the air ducts are, i have a friend who has done the same conversion, but with a std engine iam after "uping" the power to around 350bhp but i need to keep the std turbo so i get fast acceleration
    Apr 2007
    Alfreton Derbyshire
    164
    I've read somewhere that the standard S3 turbo and engine internals are only good for around 300bhp? Not sure how true this is?
    Dec 2006
    139
    For 350 bhp you will need to upgrade the turbo and associated parts...
    A 2000 S3 engine you should get about 260 after a remap...
    Goodwood Green 2001 AMK S3
    AMD remap
    Miltek cat back exhaust
    Viper DV
    Jun 2007
    300 would b fine i would like to keep the relability of the engine and box , max power with near std lag so it flys of the line
    so what would be the best way to achive a 300bhp motor with a two wheel drive box and LSD
    which gear boxes can i use ??
    what LSDs and final drives are available to suit the gear boxes ??
    Apr 2007
    Alfreton Derbyshire
    164
    Could you keep the standard engine and turbo but have a custom re-map once the engine is fitted, that way they can re-map to car the way you want it? 260-270bhp?
    S3 amd map,coilovers,upgraded heldex,lcr spliter..
    Apr 2007
    Bristol
    228
    the s3 comes with a ko4 turbo and will not make 300bhp. you can get hybrid k04 turbos that have near standard lag these use the k04 case and different internals. i think its called an ellimanator but someone will corect me if im wrong and i think you should see 300bhp plus with this.
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    you can use a 6 speed box from a seat leon cupra R as these are fwd (thats if you want 6 speed)
    Jun 2007
    not really bothered about 6 gears as it is a competition car so 5 would do fine ,
    do the engines have a alloy block ?? ( something else a friend told me )
    batwad's Avatar
    Jul 2006
    Beds
    841
    I guess you've got the engine already, otherwise you could grab a 1.8T engine out of a TT and get the gearbox and everything that goes with it in one, then remap that to the hilt
    03 A3 (8L) TDi quattro Sport, Aluminium Silver with leather, armrest, cruise, xenons and me at the wheel
    Jun 2007
    Quote Originally Posted by batwad
    ihave my name on one from a breakers not bought yet - what is better about the 1.8t out of the TT ??
    would i hit 300 easier with this set up ??
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    You'll need to make custom mounts for the engine and the gearbox, and allow for the cable change gearbox if you don't already have a suitable tunnel.
    You'll also obviously need custom driveshafts.
    There is a company that does this already, although I forget the name, they charge 10K for it and for that you get sub 4 second 0-60, so its an absolute monster.
    Your best bet would be asking this same question on www.clubgti.com/forum in the motorsport section, there will be some people on there that have already done similar conversions.
    <Insert meaningless geeky specs here>
    S3IZZO
    No, I'd pretty much forget about 300bhp to be honest if you're not upgrading the turbo (Although you should get relatively close) - You should get a better 'power at the wheels' figure than a same specced S3 though due to less transmission loss which is the most important bit I should think!
    Jun 2007
    Quote Originally Posted by S3IZZO
    its not that i dont want to change the turbo its that i want to stay away from large lag i need 0-60 rather than 15000 mph top end if you get me
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    A 1.8T engine in an Exige is near enough as fast as an Ariel Atom, better than an S3 is a MASSIVE understatement.
    If you want to stay away from large lag, then look at a 1.8T with a hybrid K04 turbo, or for less money, a K03s from a late Seat/Golf.
    The standard K04 will do about 265Bhp, the K03s has a very similar power curve but is a lot less money, and produces about 220Bhp (but looking at curves, is no less capable than a K04).
    A hybrid K04 about 280Bhp with the power curve of the K03s.
    Done properly, you'll be looking at superbike beating figures.
    Apr 2007
    Alfreton Derbyshire
    164
    If you got an engine with DBW throttle would that cause you any problems?
    Jun 2007
    Quote Originally Posted by Dave_Bayern
    REALLY i had no idea what are the stats on the 1.8 t TT ?? i was thinking on the theory that bigger was better ?
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Some more information here, and I KNOW thats been improved up, look in this months Practical Performance Car for more data:
    http://www.fourtitude.com/news/publi...ter_1245.shtml
    Basically with a standard K04 turbo, that on a standard TT or S3, in the Exige, you are looking at 250Bhp +, 0-60 in 5 seconds and 0-100 in under 10 seconds.
    Using an IHI turbo, 320Bhp and 305ft.lbs of torque, 0-60 in 4.5 seconds and 0-100 in 8.5 seconds with a better curve.
    That is PROPER supercar performance.
    The FULL conversion including engine is 7K for the K04 and 9K for the IHI.
    Almost makes it worth not bothering to do yourself......
    Jun 2007
    very interesting read !
    batwad's Avatar
    Jul 2006
    Beds
    841
    Quote Originally Posted by andy-exige
    I don't know about the 300 figure, but the 1.8T in the TT is near as damn it the same engine as in an S3, just that you'll be able to get a FWD setup.
