Chris NottAH Fabrications
Thread: Rear washer jet
    Hotscar's Avatar
    Four Wheel Drifting
    Sep 2005
    West London
    543
    Rear washer jet
    My rear washer is really struggling to give me any water but the fronts and lights are fine which is confusing. I've checked for blockages so the questions I am asking are; are there two pumps and is that the likely problem?
    Unmolested Ming blue S3 (so it doesn't handle or stop very well), Bose, sunroof and centre armrest but no heated seats - Gone but not forgotten although I am enjoying the new 350CLK!
    PSN - S3hawkster
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    check your bootlid for a water. Pipe can easily become disconnected, altenatively the central metal shaft could have broken... if its the latter VAG parts do a replacement kit for about £20.
    S3(225) - Dolpin Grey | Leather/Silver Alcantara | Bose | ViperDV | Samco Hoses | Eibach Pro-Kit | H&R Spacers | Brembo GT kit | AreoWipers | BlueTooth | Dension Icelink | New engine, Clutch, Turbo, Water pump thanks to Cambelt @ 79,000 miles | New short engine thanks to ****ed valve 22,000 miles later!
    Jun 2007
    north yorkshire
    41
    have a look around front ineer wheel arch to see if water comes down from there when you use the rear wash, mine came uncliped from here all fine now with new clip fitted.
    edward_harris's Avatar
    s3 gone now a shiney red evo 6
    Jan 2007
    berkshire, Reading
    1,062
    had the same problem on my old A3, it was the motor, tke the plastic cover off the boot lip 2 screws i think and clips, i replaced the motor and it was fine!
    Xbox online id - supaed133
    Hotscar's Avatar
    Four Wheel Drifting
    Sep 2005
    West London
    543
    Thanks for the replies!! I'll go through your suggestions Saturday morning...
    PSN - S3hawkster
