HTC said:Don't use poly bushes on the rear axle.
Consider Audi TT bushes. Solid rubber, stronger than standard.
AndyMac said:There was a thread on powerflex upgrade, it was said to be an unbelievable transformation
D-Tech Performance said:vehicles weve fitted them to in the past it has tightened the handling considerably well worth it imo
Ozzyb said:I'm looking into changing my bushes on my 1.8T 1999 to a Set of Powerflex bush Kit. Its around £127, is this worth it, will i notice the difference in ride.
nick-barnes07 said:how long does it take to fit a whole set of these bushes , and how much , cheers
D-Tech Performance said:to which model... labour is £30/h
AndyMac said:It shouldn't compromise the ride quality at all, that's what suspension is for. All it does is provide the same/more rigidity as a completely new set of rubber bushes, but without any degradation over time. Literally as soon as rubber bushes are fitted they start to degrade. You don't want any play in the bushes at all, and I'm fed up with replacing mine at every MOT.
