AH FabricationsEM Tuning
Results 1 to 11 of 11
Thread: knocking
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    knocking
    i recently replaced the springs and dampers on my car and when doing the rear i noticed that a rubber thing looked well worn. as it was late at night i had to put it back together without replacing it as i would have liked. there is now a knocking comming form the rear and i recon if i replace this it should stop as everything else looked fine. i found a picture that shows the region where the rubber thing was i just need to know the name so i can order a new pair.
    it sits around the area with the black arrow pointing at it, labled 2. i am guessing it is a bush of some description but i am unsure of the name. thanks for the help.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    That is a bump stop, it stops the suspension bottoming out, it won't cause any knocking unless its missing and you hit a really heavy pothole or bump.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    thanks a lot
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    904
    have you checked your boot for dead hookers, knocking from the rear can often be attributed to the dead hooker in the boot
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    Quote Originally Posted by cg
    thanks a lot
    Use the button!!
    Chris
    See my images @
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    i think the bump stop is the cone shaped rubber thing pointing up in the centre. i need a sort of large washer thing that sits around this. its a tid quattro if that helps. thanks for the advice
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    anyone know what this thing is called?
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    No idea, maybe the spring seat? or should it be part of the bump stop?
    Chris
    See my images @
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    i dont think so. on both sides it seemed happy to come out. i'll go to the local parts shop and see wht they say.
    bouncer--daz's Avatar
    A dog is for life....not just for friday nights!
    Mar 2007
    Gloucestershire
    543
    Quote Originally Posted by shineydave
    You werent in ipswich a few months ago were you?
    Daz - Audi A3 - 18" rs4 alloys - Weitec ultra gt 30mm kit - pipercross panel filter - tints all round - facelight rear lights - clear side repeaters - german style plates - flip out dvd touchscreen hu
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    no why
