Badger5EM Tuning
Results 1 to 11 of 11
    Sep 2005
    London
    197
    TT/A3/S3 Front hubs/Shafts
    Hello everyone, are there any differences in the front hubs and shafts between the following cars:
    1.8T TT Quattro
    S3
    A3 Quattro
    Also, did the front hubs change between Quattro and FWD cars?
    Cheers,
    Mark
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I know for sure that the 4WD and FWD hubs are different.
    Lord Vader's Avatar
    Jan 2007
    London
    34
    Thats strange as the fronts on my car I identical to the rears, hubs that is!
    They use the same bearings and hubs on my 99 S3 front and rear, as I have just replaced the hubs and bearings.
    Sep 2005
    London
    197
    Ahh sorry let me clarify, when I said hub I actually meant the whole unit; 'knuckle' is it?
    Thanks for the help so far.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    More specifics please. What are your plans?
    Sep 2005
    London
    197
    It's for my project: http://www.mwstewart.co.uk/cars/fiestaquattro/
    I want to run 17" RS4 reps (new style), so I may as well use some Quattro hubs/knuckles rather than get some adapters machined to fit the wheels on to the Ford hubs.
    I'm just wondering when I go to the breakers, if I can get some from any A3/TT etc or whether I need O2M Quattro versions (if they're different).
    Cheers,
    Mark
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Nice project!
    Right, I'm with you now. FWD deffo different to 4WD.
    As for a3 quattro versus s3/tt quattro, I seem to rememeber them having different part numbers. S3/TT have a longer hub vertically to reposition the ball joint. This is to keep correct steering geometry for factory lower suspension.
    Can't rememeber if A3 quattro has this. I'll take a better look for you when I get in from work and have more time.
    Sep 2005
    London
    197
    Cheers!
    Did you get chance to check the part numbers?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Parts catalogue lists different numbers between Quattro and S3/TT Quattro.
    Driveshafts maybe slightly different lengths or at least a change of CV joint.
    I would go for the S3/TT parts exclusively for the ability of a lower car with more horizontal wishbones. Bound to be loads of dismantled TTs about.
    Hope that helps.
    nick-barnes07's Avatar
    Jun 2007
    gloucester
    550
    hell of a project there , keep us updated how you get on , will be interesting to see the end result ,
    Sep 2005
    London
    197
    Cheers for the comments.
    Many thanks for the help HTC, its very much appreciated.
