Volks AutosAH Fabrications
Thread: will they fit
    Feb 2007
    121
    will they fit
    hello looking at some porsche rims but will 8.5j front and back fit and will i need the adaptors
    will the wheels stick out or sit inside the arche
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    A3 or S3?
    Offset of the Porsche wheels?
    Only with the offset can you guess if it'll fit or not...and although they may fit an S3...they are going to be a struggle on an A3 without arch work.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    If the offset is the same (which is doubtful) they'll fit fine on A3 or S3.
    8.5" is normal for the A3/S3 so isnt any problem whatsoever unless you have seriously lowered your car in which case the fronts 'may' rub, but again this all depends on offset.
    If all 4 are 8.5" then thats two sets of Porsche fronts, last I saw on eBay were ET44, but with the hub adaptors that will give you 10mm ish, so would bring you to ET34, and ET32 is the standard Audi wheel size so they'd be fine.
    You NEED to know the offset and the extra mm the adaptors will add.
    If they are just Porsche reps then as long as they are 5x100 shouldnt be an issue.
    <Insert meaningless geeky specs here>
