EM TuningJMB Retrofits
Results 1 to 11 of 11
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    which brake fluid?
    I've managed to grab myself a set of Brembo's at a bargain price but will need brake fluid. Which brand and spec do you guys use? How much do you need to buy to fill the whole system up? Anywhere cheap to buy this from?
    Any info is appreciated.
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    anyone? Surely someone has upgraded their brake fluid on here
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    motul rbf6000 stuff is supposed to be great.
    I'm using AP Racing fluid as it was free....
    <Insert meaningless geeky specs here>
    CLS3's Avatar
    Every penny goes on the Audi!!
    Dec 2006
    Bath/Oxford
    97
    Castrol Super Response Dot 4 is fine for hard road use. 12.16 per Litre, but i'm sure you can get it from ebay cheaper.
    http://www.merlinmotorsport.co.uk/FL...duct_info.html
    Audi S3 Nogaro Blue - Brembo GT Brake Kit, Milltek Cat-back Exhaust, Neuspeed ARB's Front 22mm Rear 19mm, Forge Motorsport TIP, Hyperboost Rercirc DV, Aero Wipers, Leon Cupra R Front Splitter, Aluminium Mirrors, Black RS4 wheels with Toyo T1R's, H&R and Forge Motorsport Wheel Spacers!!
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Quote Originally Posted by voorhees
    good comment - cheers
    Ever thought about having a section for all your threads???
    Aug 2004
    526
    Just had my Brembos fitted at APS. They used ATE super blue DOT 4.
    These brakes are soooo much better than standard. Wish I'd got them ages ago.
    Cheers,
    B.
    Utrinque-Paratus's Avatar
    Nov 2006
    Boro
    46
    Bantam1 brakes
    Bantam1 wat u using for back brakes standard ???? as im thinking of getting brembos myself
    Aug 2004
    526
    Quote Originally Posted by Utrinque-Paratus
    Yup - standard everything at the rear.
    scib4's Avatar
    Beep-Beep!
    Dec 2006
    East Kilbride
    269
    I asked a similar question on anther forum,
    "The DOT standard includes boiling point, but also includes other factors, hence some of the best fluids don't meet DOT5.1 standard despite being much better brake fluids... And just to confuse everyone, DOT5 is completely different again for silicone based fluids
    The most important factors are dry (i.e. when the fluid is brand new) and wet (when the fluid is older and has absorbed moisture) boiling points - Castrol SRF is much better, but Motul isn't too bad either - with smaller brakes on a heavier car, your fluid temperature is going to be pretty high on track...
    All brake fluids are hugely hygroscopic (absorb water), but you could add milk and two sugars to SRF and it would still out perform all the others:
    Fluid ............................DRY....... WET
    Castrol LMA DOT 3/4......446 .......311
    Ford Heavy Duty DOT 3..550....... 290
    ATE Super Blue Racing...536........392
    ATE TYP 200 .................536........392
    Motul Racing 600 ...........585........421
    Castrol SRF ...................590........518
    Performance Friction .......550...... 284 "
    The Castrol SRF is the best as you can see from the table, but is also about twice the price of Motul Racing 600!
    I use MBF 600, and never had any problems, and that includes track days!
    Mike
    Mike
    GSB1's Avatar
    May 2006
    UK
    273
    Visit GSB1's Youtube Channel
    APS put in "a good DOT4". 3000 miles later I boiled that fluid on a track event. Knowing this could occur was very off putting.
    Castrol SRF is the fluid for me now, even for road use.
    About 30 a bottle but well worth it. Don't spend all the money on brakes and have poor fluid. It doesn't work.
    MRC Tuning had it in stock when I wanted it and after the system being bled by them and the SRF used, I've never had so much pedal feel and confidence in the brakes.
    30 down the drain literally the first time you use it though as it's best to flush a bottle through on first change.
    Present: Ice silver B8 S4 s-tronic saloon (standard)
    Past: Agate grey B5 S4 saloon (MRC tuned)
    Hers: Volcano red 8P A3 Sportback 2.0 TDI CR 170 sport quattro
