Results 1 to 9 of 9
    cjhill's Avatar
    hmmmmm interesting.
    Aug 2005
    UK, South
    335
    quick brake caliper question.
    If i remove my caliper from the car, i.e disconnect the brake line, when i refit it would it be ok to just flush that particular caliper to get it working again.
    or will i get air in there that i wont be able to remove. Of course i would have to stop the rest of the system emptying whilst i work on the caliper.
    Cheers.
    Call of Duty Zombie Slasher.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,587
    You will need to bleed that caliper again, as air will most probably get in there.
    Dec 2006
    190
    And have heard of alot of people getting air trapped in the ABS system which can be fun to get out, so be careful.
    Dec 2004
    Lancs, uk
    263
    Ensure you disconnect the battery before removing the caliper.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by inigoj
    Why?
    I've never done that, ever.
    If you have rubber flexys on, you could use a hose clamp to stop all the fluid draining out, and air getting into the ABS pump.
    If you have steel braided flexys on, you're going to have to use a pressure bleeder to try to avoid getting air trapped in the ABS pump, or cycle the ABS pump using VAG Com or similar.
    Personally, if I'm doing any work on the brakes, I'll flush the fluid through each calliper at the end of the job...fresh fluid is always good!
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    never done that either?!?
    would suggest that before reconnecting to the caliper bleed the hose...and then bleed the caliper.
    S3(225) - Dolpin Grey | Leather/Silver Alcantara | Bose | ViperDV | Samco Hoses | Eibach Pro-Kit | H&R Spacers | Brembo GT kit | AreoWipers | BlueTooth | Dension Icelink | New engine, Clutch, Turbo, Water pump thanks to Cambelt @ 79,000 miles | New short engine thanks to ****ed valve 22,000 miles later!
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Just clamp the hose with a brake pipe clamp..
    Or a pair of mole grips with something around the pipe so as not to damage it. and when you reconnect the caliper just bleed it and job's a good un
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Please could you supply a reason for this?
    Chris
    See my images @
    Dec 2004
    Lancs, uk
    263
    I do not like using hose clamps, so disconnecting the battery ensures that air will not enter the ABS pump.
