Badger5JMB Retrofits
Results 1 to 8 of 8
    Lord Vader's Avatar
    Jan 2007
    London
    34
    Humming noise between 30-40mph
    Now I have done the n/s bearings as I thought it was coming from there and the o/s seam ok on jacking it up and checking, any other thoughts or previous similar problems encountered?
    Thanks in advance!
    Feb 2004
    2,036
    ONE WORD!! TYRES!!
    Its nearly nearly always the tyres on these S3s that cause hum!
    How old and what type are they, Dunlops and harder tyres like Avons are notorious for it!
    Mine was drivine me mad I was convinced it was tyres though and I was right! ! Previous owner had two rear wheel bearings though from Audi, to no avail!
    Lord Vader's Avatar
    Jan 2007
    London
    34
    Funny you should say that, someone else said tyres and I wouldn't have it.
    Oh well i'm getting new wheels soon so I see for sure then!
    Oh they are toyos on the front and goodyears on the back.
    Feb 2004
    2,036
    My monies on the rears!
    Swap front to back and see if the noise moves...
    Never had it on any car but the s3...!?!?
    Jul 2005
    2,488
    i bet its from the rear too - either a bearing or the tyres. When a rear bearing went in my corrado, it sounded like it was from the the front.
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    Yep, would put my money on tyres as well, try altering your tyre pressures and see if the pitch of the noise/humming changes.
    Also if your car is lowered you will have more negative camber which 'seems' to excerbate the bearing type noise.
    Rarrrr! I'm not Lesdyxic!
    There are three kinds of people in the world, those who can count, and those who can't.
    Clicky Here!
    Lord Vader's Avatar
    Jan 2007
    London
    34
    Good thinking about the negative camber, as when i did the n/s bearing I took out the negative camber (the three bolts on the bottom of the wishbone) and it did get a bit quieter.
    I will try changing the tyres around.
    S3 NIK's Avatar
    Mar 2007
    190
    My car made the very same noise, once i replaced the rear worn tyres the noise vanished.
    Nik.
