Chris NottEM Tuning
Results 1 to 9 of 9
    Mar 2007
    Revo Remap - Hesitation issues
    Hi,
    Recently remapped my car. I've changed the DV(at the time), Coil packs, Spark Plugs, MAF and Air filter (at the time). I still get this hesitation that so many people have experienced.
    I've read several posts (hence changing all the above!) and am running out of components to change. Can anyone think of anything I have missed?
    Would a TIP, N75 or Air intake pipe cause this momentary hesitation that occurs between 3k - 5k? And if so which is the most likely to cause a hesitation in power.
    Apologies for bringing up this issue again but I'm out of ideas and getting bored of replacing stuff without it having any effect.
    Cheers,
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    From experience, the remap itself if its the generic Revo can cause a hesitation.
    Most people who do a lot of research tend to go for one of the more specialist tuners and a better generic or custom remap.
    I know a lot of people with Revo who have this hesitation issue, and I have a superchips remap, similar hesitation but not as bad.
    No-one I know of so far with MRC, Jabba, CC etc have had this problem.
    <Insert meaningless geeky specs here>
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,900
    Sorry Dave my car was the same with tremendous lag (if thats what you mean by hesitation?) until the diverter valve was upgraded so Creepy I cannot help..er unless its your hose collapsing?
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Vorrhees - I do believe you are a genius.
    I reckon its that, the TIP collapsing....
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,900
    Quote Originally Posted by Dave_Bayern
    HA HA HA Genius you are havin a laugh aren't you?
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    See, the Revo maps are really agressive low down, so the turbo is having to pull in loads more air, hence extra pressure on the TIP, which is a flimsy thing as standard.
    Custom Code etc&#180;have a much smoother, more progressive map so there is a gradual increase in intake, as opposed to a massive pull, so the TIP is less prone to collapsing.
    This could all be nonsense but I rekcon its a fair idea.
    New TIP on ebay for cheap:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=020
    Jul 2005
    2,488
    that TIP wont fit. You're best off with a silicon jobbie.
    Mar 2007
    Thanks for the replies.
    When you say TIP do you mean the pipe that runs to the MAF?
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    TIP = Turbo Inlet Pipe.
    Runs from the turbo inlet back up to the air intake and yes, MAF. Has various take offs for DV etc.
    Rarrrr! I'm not Lesdyxic!
    There are three kinds of people in the world, those who can count, and those who can't.
    Clicky Here!
