Hi, had new brake pads fitted and he system fully bled and all fluids changed at aud last week.
Just wanted to know how the brake pedal should feel.
Mine is quite progressive with slight braking at first press getting more progressive to the bite point about 3 inches into the movement.
Is this normal for the s3???
Should the bite point come earlier??
I know the brakes are quite unresponsive and a bit vague in general on the s3 but should my pedal feel stiffer??
The pedal is a lot firmer when the ignition (abs pump) is off, this is the same on my girlfriends seat cupra, however the pedal goes a lot softer once the ignition is turned on than hers.
Dont know wether to tkae it back to hem to sort it out...if there is anything to sort out, i may just be going mental.
