AH FabricationsChris Nott
Thread: S3 Washer Jets
    May 2003
    Scotland
    42
    S3 Washer Jets
    Should they be heated? I'm fed up with a smeared windscreen and no windscreen screen wash when it's freezing. I've tried anti freeze screen wash additive but makes no difference after it's been freezing.
    I had heated jets on my last couple of cars and they are well smart. Being able to clear a smeared windscreen in freezing conditions is a must.
    PaulRS3's Avatar
    UK
    1,006
    Re: S3 Washer Jets
    I would say yes.
    I had to try and get one of mine out of the scuttle panel to try and clear a blockage, and couldnt because of the very short wire that went into it.
    that was on my 2002 S3, i assume my 2003 S3 is the same.
    Stockton-on-Tees
    23
    Re: S3 Washer Jets
    All A3/S3`s have heated jets I`m sure.
    its more likely to be frozen in the bottle/pipes, the antifreeze in screenwash isn`t that strong. The stuff i use has to be used neat to get -25c protection.
    Chepstow, South Wales
    620
    Re: S3 Washer Jets
    You could always check the fuses too I guess? (ie. make sure they're actually heating)
    By The Hole in the Wall, Kent, U. K. (The 1st Hole in the Wall not the International one!)
    125
    Re: S3 Washer Jets
    S3's Have got heated Washers, what I would do is to always use the Audi Screen Wash as on the S3 the washers are of the fan type and if you do not use a good quality washer fluid the fan jets will block. If the car is not to old then go to the dealer and get them to check it out.
    I was in Scotalnd and over night the temperature droppped to -15 degrees and that's cold!! In the morning I started the car, thoughtlessly pressed the screen washer and no frozen washers and they did not freese at all the time was 9.00am and the temperature was a positively sub-tropical
    -11 degrees!!! [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/shocked.gif[/img]
    May 2003
    Scotland
    42
    Re: S3 Washer Jets
    OK chaps. I think I'll get them checked. I'm talking about temps just below freezing. In extreme conditions for this place like 15 below then I would have expected them maybe not to work but this is like 2 and 3 degrees below and they freeze.
    Ian
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
