Volks AutosAH Fabrications
Results 1 to 12 of 12
Thread: S3 MISSFIRE
    May 2007
    7
    S3 MISSFIRE
    HI CAN ANYBODY HELP!!?? I SEEM TO HAVE A MISSFIRE, WHEN REVING THE CAR AS THE RPM REACHES 4,000 RPM THER SEEMS TO BE A MISSFIRE ON ONE OF THE CYLINDERS FOR APX 1,000 RPM, I HAVE HAD THE CAR PLUGED INTO VAG COMPUTER BUT IT DID NOT SHOW ANY FAULT CODES?? ANY ADVICE WOULD BE GREAT!
    Tastyterrier's Avatar
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    Faulty Coil Pack?
    A3 1.8TQS: Supersport Springs and Shocks, Xenons, BMC Filter, 18" OEM TTV6's, Bailey DV, N75J and Phase 1 Custom Code.
    May 2007
    7
    s3
    Im not sure, shouldn't have that shown up on the vag computer??
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    I aint no expert, but I know that with a faulty MAF, an error isn't always recorded, possibly the same with a coil pack.
    I'm sure someone a lot more knowledgable than me will be along soon!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,850
    Are you 100% sure it's a missfire? If it's a coilpack problem, it should come up on vagcom, and should bethere throughout the revrange, knackered MAF would feel like a missfire, but it's more an uneven power delivery throughout the rev range.
    You've got to have a laugh!
    Oct 2006
    86
    The ECU will not always flag a misfire. It needs to be very serious to bring the Engine light on.
    if you log engine groups 015 and 016 on VAGCOM you will see individual cylinder misfires, if you drive up the road and repeat the conditions the misfire occurs, you should be able to tell which cylinder is the problem.
    Swap the coil ( but not plug) with another cylinder, repeat the test, if the fault moves you know its the coil. If the fault stays with the original cylinder repeat with the spark plug only, this should tell you if its plug. If it doesnyt move you then need to repeat with both coil and plug moved. If the misfire stays in the original cylinder when you have moved both coil and plug you need to look at MAF.
    Log engine 02 and this should give mass reading. a chipped S3 should consume 190+/- 10 g/s around 5600RPM. If you are much less than this then MAF could be at fault.
    Not sure MAF readings for Std S3, have a search and you chould find the values.
    HTH.
    Oct 2006
    86
    4000rpm is near peak torque which is higher cylinder pressure which is higher voltage demand which means more likely coil or plug.
    Sep 2006
    Surrey
    1,224
    Maybe just bad petrol? Something redex might fix...
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    Missfire's are normally from dead coils or sparkplugs but both would show on the vagcom. Try cleaning the maf and throttle body and reset the ecu, see if that helps.
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    925
    I have had a intermittant misfire for months,no codes showing ,i changed coilpacks,plugs no joy,it got worse and vagcom showed a intermittant lamda fault,changed it yesterday and the car is now fine again?It was misfiring in midrange ,normal slow speeds all ok ,as soon as it hit 3500-4000 it was popping and backfiring?I shall see if it stays ok and keep you posted.Cheers Andy
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO MAP ,STATIS CATBACK EXHAUST,PANEL FILTER.
    Feb 2004
    2,036
    Whip out the spark plugs, agree again on it being near peak torque, could be a plug melt through oinking or detonation if you run higher boost and had some bad fuel in it.
    If there is a plug melted, find out what did it!!
    ANDYTQ's Avatar
    Oct 2003
    925
    It started misfiring again checked plug gaps ,they were too big,regapped them and misfire is gone.Result
