    DavyJam's Avatar
    Jan 2007
    S3 Brake Problem
    Just wondering if anyone has experienced this before, the car I have is a 2001 S3. Basically my brakes appear to not be working correctly, luckily the problem only started happening when i was about 200 yards from home.
    Symptoms are that the brake pedal can now be pressed right to the floor and it is only then that the brakes start to work, but no where near as efficiently as they where doing. No brake related warning lights come on the dash, but the ESP warning light comes on and stays on as soon as the pedal is pressed.
    Had the car serviced December 2006, all the brake pads, disks, etc where replaced and everything has been fine for last 6 months.
    I'm obviously stuck for getting this looked at today/tomorrow, just wondering if anyone has any ideas as to what the cause could be?
    edward_harris's Avatar
    s3 gone now a shiney red evo 6
    Jan 2007
    berkshire, Reading
    1,062
    have you checked the fluid level?
    Xbox online id - supaed133
    DavyJam's Avatar
    Jan 2007
    I did take the cap off and check the fluid and it seems fine.
