Chris NottEM Tuning
Results 1 to 8 of 8
    Jan 2007
    198
    Aircon - worked this morning - not now!!
    All,
    Lovely time of the year to get this problem.
    Got an A3 pre-facelift with climate control, the air-con was working beautifully this morning, but put it on later, and it didn't cool the air... asr3.
    The only thing I did in the meantime was run the engine, stationary, with me in the car, air-con on for about 10 mins - worked fine then.
    Next time I get in the car - no cooling.
    Answers on a postcard to the address below....
    Cheers Jas
    rodenal's Avatar
    Oct 2006
    1,982
    Hit it with a hammer
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Jan 2007
    198
    Quote Originally Posted by rodenal
    What size hammer?
    LMAO
    Jas
    Jun 2003
    World of my own
    9,813
    Is it not blowing at all or just blowing hot?
    Jan 2007
    198
    Blowing hot. No chilling action.
    Thoughts?
    tonedef's Avatar
    Mar 2006
    Chesterfield
    147
    When mine packed up it was the clutch had fallen off the compressor???
    2001 S3|Ebony Black|Revo|MTM Clutch|RS4 Reps|Tarox Brakes
    '95 Corrado VR6|Classic Green|Koni/Eibach|Undergoing major rebuild!
    tonyt102's Avatar
    Mar 2006
    Cleveland
    88
    Can you hear the compressor start when you switch the climate control on? If it's not coming on, it could be a few things. One of the most common is that the gas is low which triggers a switch to stop the compressor working.
    If it's actually blowing hot air through, the temperature control flap could be stuck. I had the same problem in my B6 S4. They were quite easy to get to on the S4 although I'm not sure on an S3.
    :: Audi S4 B6 :: 53 reg :: SILVER :: DVD SAT NAV ::
    Apr 2007
    82
    As has been said above
    When the Aircon/Climate is turned on when the compressor kicks in the revs should pick and then when pulled drop off.
    If this doesnt happen the compressor isnt kicking in which could mean low levels, maybe due to a leak?
