Chris NottSky Insurance
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    big problem, suspension
    i am replacing the rear suspension and have come accross a problem putting it back together. when fitting the lot back together i cannot remember whether it goes
    nut, damper, droplink, hub
    or
    nut, droplink, damper, hub.
    please help me as my car is in bits. thanks
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    come on there are 33 people on line at the moment. could one of you please go out and have a quick look.
    Feb 2004
    2,036
    are you talking about the rear lower shock mounting ??
    I will have a look if you give us a clue what you are on about! !!lol
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    yes where the rear damper attaches at the bottom to the car.
    there is a bolt that goes through the damper and anti roll bar droplink then attaches to the hub. i just need to know whether the damper is forst or the droplink is first
    Pat
    Dec 2006
    512
    The bolt goes through the droplink 1st then shocker then into hub.. Hope that helps..
