Volks AutosSky Insurance
Results 1 to 20 of 20
    Nov 2006
    Onchan, Isle of Man
    9
    Engine swap possibilities
    Ok, so my long suffering S3 (APY) engine is finally out of the car waiting to be stripped.
    Before I find out the cause of my problems (an ominous knocking) - I've spotted a couple of spare engines on ebay.
    I've found an (APY) with less mileage; but I also spotted a (BAM) 225 version.
    You can guess where I'm going with this right?
    If I was looking for the BAM replacement - is it going to fit? What about wiring and ECU etc?
    Thoughts appreciated.
    T.
    rodenal's Avatar
    Oct 2006
    1,982
    The engine will fit just the same, but i'd imagine u'd need the ecu and the wiring might be different too.
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    S3IZZO
    I have exactly the same problem (knocking) and am looking at the same thing (engine out) ... let me know if you find the cause of it, mines due to be looked at on wednesday.
    edward_harris's Avatar
    s3 gone now a shiney red evo 6
    Jan 2007
    berkshire, Reading
    1,062
    hope it's not as major as mine was!!
    Xbox online id - supaed133
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    whats the difference in the engines, AYP, BAM and AMK
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
    S3IZZO
    Quote Originally Posted by edward_harris
    What was wrong with yours?...and what where the symptoms?
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Quote Originally Posted by rickparmar
    I think the APY was non-DBW, so putting in a drive-by-wire engine will cause allsorts of issues.
    Ed, any chance of sorting out your sig pic size?
    [/sarcasm]
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    All S3 engines are DBW. The ayp is non vvt i think
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Quote Originally Posted by mk1chopper
    Correct, my APY is DBW, don't listen to Chris! all that BHP is starting to mess his mind up!!
    You've got to have a laugh!
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Quote Originally Posted by jojo
    lol
    What is vvt in the engine ?
    Still need Remap
    2007 Audi S3 8L
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    lol
    Variable valve timing
    S3IZZO
    vvt = variable valve timing ... not to be confused with VVT on Hondas or Toyotas though, only works on idle I think I remember reading somewhere.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Quite possible! I have my mind on other things, and I wasn't 100% sure when I said it (but I knew you'd be along to correct me if I was wrong).
    [/sarcasm]
    Oct 2005
    England
    101
    Im pretty sure the APY is vvt but its a mechincal simpler version the the electronic vvt on the AMK-BAM
    Apparently the pistons are larger on the APY shorter stroke or something
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Quote Originally Posted by 242spot
    The vvt is operated by Solenoid and mechanical on APY and electrical in operation on AMK and BAM engines IIRC. it's only there to make the car's emmisions Euro compliant during idle as mentioned earlier in the post.
    APY engines have 20mm Piston pins as oppsed to 19mm ones in AMK and BAM engines... this is all info I have picked up on from reading these forums, so correct me if I'm wrong!
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Doesn't your APY have a larger ported head too?
    [/sarcasm]
    Jul 2006
    61
    eurospec do some nice strong engines. i hear the exchange rate is good as well, lots of potential for tuning if thats what your into.
    dultanur's Avatar
    all promises, no action :)
    Sep 2006
    Istanbul,Turkey
    407
    no, the APY has the small port heads. i think only the AGU on the A/S3 series has large ports.
    2000 Black S3 (Sold, then totalled) - 2008 A3 1.4T Sport
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Same bore, stroke & capacity for apy and bam. Use block/head (or whatever's broken from bam). Fit hydraulic cam chain tensioner from apy to bam head and it'll then be non-vvt.
    ECU will cope.
    Nov 2006
    Onchan, Isle of Man
    9
    Finally got the car back today, with a new block and some other refinements.
    Turns out the "knocking" was a shattered middle piston ring on the 3rd cylinder; I now have it in a plastic bag to remind me of the pain. The conrod on the same cylinder was also slightly bent; as a result of the piston ring there was oil residue over the valves and manifold port.
    Contemplated replacing all the internals - opted for the new block from Audi with 12 months warranty.
    T.
