JMB RetrofitsChris Nott
Results 1 to 36 of 36
Thread: WOW!
    Apr 2007
    98
    WOW!
    Hi All.
    Had my s3 for about 1 month now, i was happy with the speed and acceleration but it didn't have quite the pace i was expecting.
    Cleaned the maf the other day....had no effect. Cleaned the throttle body and reset ecu yesterday and OH my god it shifts now. It feels like a different car, even the slightly eratic idle has gone.
    If anyone has bought an s3 recently and has not done this 10 minute procedure i highly recommend doing it.
    Really need to upgrade the suspension now though.
    Thanks for the posts on here that helped me to carry out the simple cleaning job.
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Quote Originally Posted by mrj0ey
    Hi All.
    What did you clean it with and how did you reset the ECU? was it an easy task?
    Apr 2007
    98
    Hey
    I used some autoglym engine cleaner, however carb cleaner is probably stronger. I scrubbed at it with a scouring pad from the kitchen. Some grime came off easier than others....but it poloshed up a treat.
    To reset the ecu search for some more detailed posts on here. Basically though you disconnect the battery (positive terminal) leave it for 15 mins (clean throttle body) reconnect the battery. Put key in ignition and turn till all electric check lights come on. Wait for ticking/buzzing nosie from throttle body to clear (about 30 seconds) then turn ignition. Idle will be dodgy for a few seconds. leave on idle for a while then go and check out the difference. Think you have to drive for 10 mins or so, the ecu learns how you drive and adjusts things to maximise efficiency and performance i guess!?!?!
    Sep 2006
    Stockport
    241
    Yeah could you tell me how to clean the MAF and throtle body etc. I fancy havin a tinker with mine.
    Any other routine things anyone can recommend
    Oh and whats the MAF
    51 reg A3 1.8 Sport, 17"TT Alloys, Centre Arm, Leon Spliter.
    Stockport
    17 - Pug206, 19 - Punto, 23 - A3
    http://s154.photobucket.com/albums/s...rst_widget.pbw
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Nice one - job for the weekend.
    Apr 2007
    98
    maf is easy, just remove it and spray some electronic contact cleaner in there. It didn't have any real effect on my car as it was clean anyway, however you may see better results... you gotta clean the throttle body though. Loads of searches on the forum. Really is easy to do, cant believe the difference.
    My throttle body was quite dirty though, nearly 100k, yours maybe ok so not as much performance will result from a clean.
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Where is the throttle body and the maf? For us not so technically minded people!
    J
    Sep 2006
    Stockport
    241
    Would mine have MAF as its not a turbo
    Also before anyone says it I have done a search for cleaning MAF and throtle body but all the links go to dead pics.
    Any help would be great
    Stockport
    Sep 2006
    Stockport
    241
    Found this for MAF cleaning
    http://www.wak-tt.com/mafclean/mafclean.htm
    Stockport
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    I found something, but off an old A4 so not sure if it will be the same set up or parts as mine!
    J
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Quote Originally Posted by garratt83
    That look's far more up to date! Thanks garratt83!
    J
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Here we go - I've found one for throttle body cleaning
    http://uk-mkivs.net/forums/thread/222737.aspx
    Apr 2007
    98
    Those are the threads i used. Really is quite simple, have a look at your engine and you will see where everything is. Rotate the s4 picture 90 degrees and that is similar to the s3 engine.
    Jan 2007
    198
    What else can be used if not carb cleaner??
    I know Isopropyl alcohol can be used on the MAF.
    Jason
    Apr 2007
    98
    Hey
    Anything really, it has to be quite strong to shift the grime. I used autoglym engine cleaner and a scouring pad!
    Apr 2007
    31
    Just done this after reading this post after putting it off for ages thinking it would be hard but was pretty easy thanks to the guides
    Mine didn't have to much dirt although my cars done 76k but its now nice and clean!
    Cleaned it with degreaser,kitchen towel and cotton buds
    CLS3's Avatar
    Every penny goes on the Audi!!
    Dec 2006
    Bath/Oxford
    97
    Any difference in the cars performance at all?
    Audi S3 Nogaro Blue - Brembo GT Brake Kit, Milltek Cat-back Exhaust, Neuspeed ARB's Front 22mm Rear 19mm, Forge Motorsport TIP, Hyperboost Rercirc DV, Aero Wipers, Leon Cupra R Front Splitter, Aluminium Mirrors, Black RS4 wheels with Toyo T1R's, H&R and Forge Motorsport Wheel Spacers!!
    May 2007
    67
    can i do this to my 2001 1.8t. im not that good with cars but im sure i could do this after looking at the pics. is there anything i should look out for. any help would be great.
    cheers matthew
    Apr 2007
    31
    Quote Originally Posted by Chris-A3 1.8T Quat
    I've only drove a few miles to and from work but the throttle response is a bit better and i seem to have better MPG on the computer then i normally have
    Apr 2007
    31
    Quote Originally Posted by wackojacko
    cheers matthew
    Yeah you can do it on yours and its really easy thanks to the pics.just make sure you remember to connect the wires when you put it back on and you should have no problems
    b13
    b13's Avatar
    Dec 2006
    12
    Just done mine it's an easy job. Will let you know how it performs.
    May 2007
    67
    do u need to disconnect battery before i start as i might av a go tonight
    b13
    b13's Avatar
    Dec 2006
    12
    Disconnect it before you start to save a bit of time. The hardest bit I found was removing the electrical connector. Should take you about half an hour to do. I would like to post some before and after pictures but I'm not to sure how to.
    May 2007
    67
    another daft one.
    do you need the radio code. as at the min i dont have it so will i need it before i do the clean?
    also will engine degreaser be ok to clean the maf and the throttle thingy?
    cheers
    b13
    b13's Avatar
    Dec 2006
    12
    You'll need the radio code if you disconnect the battery. I used carb cleaner very quick and easy.
    S3 Left Hand Drive 2000 210bhp Metallic Black Green Air Filter, Cat Replacement Pipe, Heated Seats, Heated Mirrors,TT Pedals,Bose Stereo
  28. #27
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    another daft one.
    cheers
    You wont need the code if its canbus, the radio is coded to the car. Also i would very carefull what you clean the MAF with, its best to use something with 99% alcahol like isopropanol. Ive nacked a few in the past by using stuff like meths that leaves residue.
  29. #28
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    I took my intake manifold off and it was spotless.
    the MAF looked a bit dirty though so i took it out and gave it a quick spray with engine degreaser and carefully wiped it off with a cloth and the car seems the same.
    It may be ever so slightly smoother but that could just be from resetting the ecu.
  30. #29
    rodenal's Avatar
    Oct 2006
    1,982
    God u wiped ur maf!!!!?????
    Not a good idea those wires are very sensitive
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
  31. #30
    May 2007
    67
    Quote Originally Posted by petewon
    how do i know if my radio is canbus?
  32. #31
    May 2007
    67
    which part ov the maf do i spray with the carb cleaner as i dont want to spray the wrong bit. a pic with an arrow would be excellent cheers
  33. #32
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    When you hold the MAF in your hand, right at the tip of it is a gap with what should be a thin bit of metal film in it, spray there.
  34. #33
    Apr 2007
    98
    yeah, a cavity with two metal pin type of things inside. spray away in there!
  35. #34
    Apr 2007
    16
    Just cleaned my throttle body and cleaned the MAF with isopropyl. Just drove the 10 miles back from my bros house and and am getting 33mpg now instead of the usual 27mpg!!! Got to admit the low end response feels loads sharper...Will give it another spin in a bit. Throttle was well mucky and MAF was a little dusty, just gave it a thorough soaking with the spray and then left it 1/2 hour. Would be careful when cleaning throttle body though as there are some electrical connectors on it that I did my best not to get damp. Seems loads better now though
  36. #35
    nky_84's Avatar
    Oct 2005
    Edinburgh
    433
    Im going to do this at some point as the cars touching on 50K and i cant imagine it has ever been done.
    Going to do a few tests before and after to see if it does anything as im a bit dubious. Might do a 0-60 and some sort of mpg comparision so we'll see if it makes a difference to mine.
  37. #36
    Utrinque-Paratus's Avatar
    Nov 2006
    Boro
    46
    Good posts guys very helpful really glad I joined this site, thank you for your feed back.
