    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    Drivers side window questions
    Hello everybody,
    Had a problem with my drivers side window this morning (it wind down) it seems the motor has packed up i cant here any movement at all. I just wanted to ask if there is a seperate fuse for this window, the passenger works fine. Also should i require a new motor can anyone recommend where i can find a used one ?
    Any help or advice would be appreciated i did do a search but didnt come accross any of the above.
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    rodenal's Avatar
    Oct 2006
    1,982
    I'm sure i've seen something on this before, when you press the switch does the window try and come up but sounds like its hitting resistance?
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Jun 2003
    World of my own
    9,813
    Try pulling the window up with your hand at the same time as pressing the up switch.
    A common problem is the frame runners get distorted so the motor feels the resistance and drops the window as a safety feature so as not to crush a small child.
    Nov 2005
    UK
    1,688
    Its very strange,the window is up BTW. It happened on the way to work this moring at lunch time i went out to have a look / check it out etc, the window is working fine now very strange :-$ (mind boggles)
    wanted for 8L S3:
    Milltek system
    A3T
    A3T's Avatar
    Every Dawg Has Its Day
    Mar 2007
    london
    27
    could be your regulator playing up a bit.....
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,430
    Spray some silicon alond the runners on the doorframe, I had the same problem and it's cured it, I also have some A6 window clips on standby, just incase they may actually be broken.
