Sky InsuranceEM Tuning
Results 1 to 7 of 7
    Mar 2007
    Cambs
    471
    1.8 T sounds like exhaust is blowing then starts up?
    Hi all,
    Recenty got the A3, on cold start up it sounds just like the exhuast is blowing, coming from under the bonnet id of thought it was from the manifold, but then the revs drop and it goes compltely silent?
    Is this normal? it sounds like its on choke, then warms and revs drop, or is it some kinda pressure release valve?
    Cheers for any info
    Dave
    Mar 2007
    Cambs
    471
    anyone?!?
    buckas's Avatar
    Sep 2006
    south west wales
    750
    completely normal, IIRC it's a secondary air pump/fan - Pumps air into exaust system during warmup to heat the cats up quicker. Emmisions device to lower pollution etc. lasts for about 1 minute
    drew
    Mar 2007
    Cambs
    471
    Wicked, cheers mate, put my mind at rest now
    shollis's Avatar
    flat in fifth.....
    Jan 2007
    Derbyshire
    48
    My 1.8 T did exactly the same thing when I got it (blowing of air sound for the first 60 seconds of start up from cold), it turned out that the rivets holding the secondry air pump together had broken so a lot of the air being produced went straight out of the side of the casing. They are a pain to get off but I managed to get at it enough to drill out all of the rivets which had broken and replace them with bolts. It is now a lot better although not silent but according to several specialists I have spoken to this is normal as the engines run like a bag of spanners when cold for emmisions reasons.
    Hope this helps.
    Jan 2007
    Hertfordshire
    520
    What he said :D Mine sounds like a tribal band playing under my bonnet until the revs drop, my friend commented on it the other day.
    silver75's Avatar
    Big Ron
    Sep 2005
    at work
    3,243
    Quote Originally Posted by shollis
    Hope this helps.
    good post
    Big thanks mate im currently also having this problem and was wondering what it was
    Smart Roadster 03
    Ford Sportka 05
