Badger5AH Fabrications
Results 1 to 19 of 19
    Audi S3 (2000)
    Mar 2007
    303
    Break pad warning light
    came on this morning. should i get it looked at right away? how long before they ware out?
    expensive month this month
    S3 NIK's Avatar
    Mar 2007
    190
    I would as the longer you leave things the worse they generally get and the cost gets higher. Leave them too long and you risk disc damage.
    A friend was quoted 100 quid to replace front and rear pads on a 225 TT at a specialist as a guide price for you.
    Nik.
    Quote Originally Posted by mordz
    monkeytrousers's Avatar
    Jul 2004
    East Sussex
    372
    You probably have about 1,000 miles left. Had mine done a couple of months ago: £95 fitted from Audi independent.
    Audi A4 3.0 TDI Quattro 2008 - Ice Silver
    JUST GONE: BMW 330i M Sport Saloon 2006 - Le Mans Blue
    GONE BUT NOT FORGOTTEN: Audi S3 Quattro 2002 - AMD stage 1 - 261BHP - MTM clutch - Brilliant Black
    Audi S3 (2000)
    Mar 2007
    303
    thanks guys, not as expensive as i though. for some reason i had 350 on my mind
    im not 100% sure like these warning lights, always scares me when they beeb and come on, im like what the **** is that
    rodenal's Avatar
    Oct 2006
    1,982
    I spose your approach is correct seeing as its to do with the brakes, dont worry too much about it but get them changed soonish - its a 10 min job yourself btw, cost you about £40.00 all in to do front and rear.
    If you're worried about how much wear there is just take a look at the pads from a bove, if they're down to the metal you'll soon spot it
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    S3 NIK's Avatar
    Mar 2007
    190
    Do you not need a special tool to wind the pistons back in?
    Nothing worse than taking something to bits to find you can't put it back together again, especially on a Sunday afternoon.
    Nik.
    Quote Originally Posted by rodenal
    I spose your approach is correct seeing as its to do with the brakes, dont worry too much about it but get them changed soonish - its a 10 min job yourself btw, cost you about 40.00 all in to do front and rear.
    pav-g's Avatar
    Jan 2007
    Bradford
    728
    Just following thread, my breake light came on and yes you have around a 1000 miles before the pads are totally dead - to replace all four will cost in the region of 95 to 125 from an independent garage and once new ones are in the light will go off. Good luck
    Audi S3 (2000)
    Mar 2007
    303
    haha yeh been there, im not sure ill tackle it by myself considering i havent doen it before.
    :S
    Quote Originally Posted by S3 NIK
    Nik.
    Audi S3 (2000)
    Mar 2007
    303
    just had a quick look at all wheels. theres about 7-8mm left on each wheel apart from one rear that has about 4-5mm
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Can't beat a visual inspection as the sensors are known for playing up. 7-8 mm of friction material is quite a lot given you probably only get 15mm or so on new pads.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Audi S3 (2000)
    Mar 2007
    303
    thats what i thought. the seller told me he had just put new ones on as it had gone through the MOT. this is back in feb. i done around 5-6k since then though
    how i bout i take the wheels of and use an air line to blow out all the crap?
    where abouts are the sensors?
    rodenal's Avatar
    Oct 2006
    1,982
    Yeah i'd say those were alright to be honest - about the caliper you shouldnt actually need to push it back the pads slip on and off the disc relatively easily(a bit of brute force required) - especially the fronts which are a piece of cake
    rodenal's Avatar
    Oct 2006
    1,982
    Actually scrap that you will need it on the rears, but not on the front
    rodenal's Avatar
    Oct 2006
    1,982
    Sensors are built in to the face of the pad you wont be able to see it iirc
    Audi S3 (2000)
    Mar 2007
    303
    ok, i may have a go at taking them off. ill blast it with the air line first see if it stopps the beeeeeeeeeeeeep
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    When the sensor on mine went beep (only half worn pads), it wasn't the sensor in the pad that was at fault, it was the connector further into the wiring loom that had shorted and needed replacing.
    Jason
    Audi S3 (2000)
    Mar 2007
    303
    is there anyway to test this sensor?
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    continuity test with a avo.
    red to red black to black blue to bits
    Audi S3 (2000)
    Mar 2007
    303
    Quote Originally Posted by fingermouse
    ta dude
