EM TuningMonster Motorsport
Thread: Warped Discs?
    Nov 2006
    South coast
    Warped Discs?
    Wondering if anyone else has experienced this:
    When heavy braking from v.high speed (on my own private motorway of course), say at the termination of a motorway, my brakes make a real grumbling noise. At first I thought it might be the ABS, but its way too noisy for that. I can feel the grumbling through the wheel and the brake pedal. What do you reckon it could be? Surely not ABS, I've experienced ABS\ TSC on this S3 and plenty of other cars and none are this "unrefined". Warped discs? Loose front suspension components somewhere?
    It's odd, coz the brakes behave perfectly well elsewhere (although they could be better) such as normal driving, and even B road blasts. It just seems to happen on roads where you have a real head of speed up, and brake heavily in a straight line for a roundabout. I only had the car serviced in November, about 5k miles ago, and there were no reported problems with the discs or pad wear.
    Any suggestions appreciated...
    larsmate's Avatar
    Apr 2004
    114
    Black S3 | MY09 | APR 3.4 Stage 2+ | RNS-E LED | Tints | 19" OEM RS3 Rotors | APR DP | APR HPFP | WALK | Bilstein B14 Coilovers | Lamin-X | Ashtray delete | P3 Gauges integrated boost gauge | BlueVAG VAG-Check |
    rodenal's Avatar
    Oct 2006
    1,982
    Very very unlikely for a disc to just warp, only really possible for you to do this when they're brand new - if you're braking from a very high speed then its prob more likely that the crap brakes cant really handle it
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    joe6886's Avatar
    Sep 2006
    245
    Its more than possilbe to warp any discs regardless of age. Sounds like you've just used them too hard.
    Nov 2006
    South coast
    I've only had the car since October, and admittedly the car had the same "Feature" back then, so I can't be anything to do with me mullering the barkes since buying it. I guess it must be either very very uncouth, noisy ABS, or the discs need replacing. I'll get the garage to check it out when the car goes in for it's cambelt in the next couple of months.
