Results 1 to 30 of 30
Thread: bose sub
    Feb 2007
    121
    bose sub
    qustion have bose stereo and the subs sound rubbish the reset of the standard speakers sound ok but the subs flap and phart and sound bad
    is the any way of gettin them to sound better i do not want to change the standard head unit as i do not want to ruin the look of the dash so running a amp is not poss with the standard headunit anybody got any ideas the best way to do it
    Jun 2003
    World of my own
    9,813
    Swap it for a stealth sub. You will need to run a new amp, but this IS totally possible & easy with the stock HU (not sure why you think you can't). At around 300 (including sub, enclosure, amp & wiring) it is the biggest single upgrade you can do in the A3/S3.
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    thats cool andy did you do all the work yourself??
    what size sub is that?? 6"??
    S3 - Gone but not forgotten!
    s3ollie's Avatar
    Jan 2007
    749
    now this looks like an idea instead of replacing my broken bose sh*te subs (if you can call them subs at 4" each!)
    AndyMac do you have the diamentions and/or a how to for this please
    Feb 2007
    121
    hello mate how can i run a seperate amp for the box with standard head unit and where can i get the box and stuff from
    Jun 2003
    World of my own
    9,813
    I provide the enclosures, which are custom made from 18mm MDF. I wouldn't recommend making one yourself as there's a lot of work and it took me 3 versions to get it right. The enclosure on it's own is 95 (satin black with wadding, wiring, gold terminals & brackets), the JL Audio 6W04 6.5" sub is 85 and I can supply the amp as well if required. I only use Alpine V12's sourced off ebay & fully tested, either 2 channel T505's 300wrms bridged for Bose system or 4 channel F400's for non Bose system (as the rears are powered by the sub amp).
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,617
    But youy'll be DEAF in a few years.......DEAF I SAID ANDYMAC
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Andy- is the sound difference remarkable better between the standard bose sub and the enclosure,amp and sub you supply?
    i would be interested in buying one off you, the standard sub can sound reasonable on some music but its not perfect.
    if you supplied the amp, sub, enclosure how easy is it to fit?
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Can i just add that the Andymac Bose upgrade is a work of art, I've had mine fitted by myself for a couple of years now and it makes a huge difference over standard.
    You've got to have a laugh!
    Jun 2003
    World of my own
    9,813
    It is a drastic improvement, cleaner punchier bass, at much lower bass settings on the HU, so the cabin speakers are freed up from trying too hard so it also improves the clarity at the top end.
    PM me your mail address and I'll send you the instructions. It's not complicated just time consuming, takes me 4 hours to install.
    s3ollie's Avatar
    Jan 2007
    749
    can you run the Andymac sub off the bose amp or does it require and extra one
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Quote Originally Posted by s3ollie
    The Bose Amp is 4 channel, so runs the 4 speakers and tweaters in the car, the sub has it's own mini Amp which is a circuit board the size of a fag packet with a few things stuck onto it, so you will need a seperate Amp to run it... with the instructions that Andy will supply you, it will be hidden inside the rear quartter panel next to the rear seats.
    S3IZZO
    I love the look of that!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Adrian, I've replied to your PM, let me know if you would like a demo ok.
    Mar 2007
    Cambs
    471
    Hi all,
    Ive just got my A3 and it has the 2 little subs in the boot, just above is the cd changed, then to the right of the changer is another..thing?!? which looks like another changer? but isnt!
    I have Sat Nav and TV so is it something to do with that?
    Dave
    buckas's Avatar
    Sep 2006
    south west wales
    750
    Quote Originally Posted by campbell
    aye, same question for me too - very interested aswell indeed
    drew
    Aug 2006
    Denver, Colorado
    41
    that is a really nice looking sub-box. very cool and clean. i hate seeing literal "boxes" that just sit in the middle of somebodys trunk. it looks so messy and unfinished.
    anyways, how it is attached?
    cheers!
    Blunteh's Avatar
    Mar 2006
    South East UK
    198
    Quote Originally Posted by Cossie_boy
    Hi all,
    Dave
    Yes it holds the data disc for the Sat Nav.
    Nogaro Blue 2001 S3 - Revo Remap (Stage1) - Hyperboost DV - Neuspeed 22mm + 19mm ARBs
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Andy
    Can you let me have the fitting instructions also....been thinking about and ready good things about your stealth sub for a while now.
    Marcus
    PS anybody in or around Bristol with one of these for a sound demo?
    S3(225) - Dolpin Grey | Leather/Silver Alcantara | Bose | ViperDV | Samco Hoses | Eibach Pro-Kit | H&R Spacers | Brembo GT kit | AreoWipers | BlueTooth | Dension Icelink | New engine, Clutch, Turbo, Water pump thanks to Cambelt @ 79,000 miles | New short engine thanks to ****ed valve 22,000 miles later!
    Jun 2003
    World of my own
    9,813
    PM me your email address for the instructions
    djwillb's Avatar
    Newquay
    65
    Can we stil get these?
    2001 Audi S3
    Ming Blue - Bose - Silver leather - Chrome mirrors - Cruise control
    Revo Stage 2 - Koni FSD Suspension - RS8 19" Wheels - Facelift Headlights & Rears - Brembo drilled disks & Red Stuff pads
    Forge 007 - 4 Bar FPR - PiperX panel filter - Milltek Exhaust - LCR Splitter - Private S3 Plate
    Just bought and awaiting fitting - Reiger front bumper & carbon splitter,
    Warranty paintwork and full respray being done end of the month
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Yes, I'm pretty sure he is still making them. Best upgrade I did on mine!
    He even has one for the 8P now.
    PM andymac for pricing etc.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    Jun 2003
    World of my own
    9,813
    Thanks for the praise Ali, yes I'm still making them, 72 sold and still going strong!
    Alex Turner
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by AndyMac View Post
    I'm not suprised mate, that looks like an absolutely pukka job.
    Top work!
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    G60DAN's Avatar
    Cornwall
    318
    Hello
    Im new 2 the forum had my S3 a month and a half now and need 2 sort out the bose sub. As it's not up 2 much I would like 2 run an amp with sub with oem H/U can someone help. all I need 2 know is how 2 wire it up I can make the box as Im a chippie.
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    that does look the tittys andy mac. how bigs the face of your enclosure? could you fit a square kicker as those small little feckers thump? i would love to have my whole boot back but i love my 2 12"s to much
    i assume you cant mount a sub in the other side as well?
    Now to many mods to list! Lots of power, torque and Leather!
  28. #27
    Chugger
    North Devon
    2,716
    Iv just fitted a AMSS, and it sounds the daddy, i was massively surprised how much bass is given out by the tiny sub. Couldnt be doing with subs in the boot, ruins the image for me
    57 A3 2.0 TDI Sportback (140)
  29. #28
    Mar 2010
    Durham NE
    575
    how much do these go for? i would love one as the stock one is poop!
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
  30. #29
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Just PM AndyMac for pricing. I think he still does a fitting service as well, if you can get to the Portsmouth area.
    Cheers,
    Alistair
    Arnold Rimmer, 1988
  31. #30
    Mar 2010
    Durham NE
    575
    done thanks
    James
    Silver Audi 8L S3
