Badger5AH Fabrications
Thread: Whinning noise
    Dean_20's Avatar
    Oct 2006
    Middlesbrough
    65
    Whinning noise
    now guys, recently noticed a whinning noise coming from the front when i get to about 20mph+, once at this speed the noise stays there all the time?
    what do you think it could be, a bearing?
    Audi S3, 2003, standard!!
    Feb 2004
    2,036
    More likely is tyre noise tbh. Some tyres when even a few k miles old made a huge racket on the S3's for some reason. Normally the rears tbh.
    Try swapping your wheels around the car and see if the noise moves? How old miles and what size / makes tyres may help us diagnose it too!
    how many miles has the car done..? Unless you hit something a bearing is unlikely to go before 100k on a stock car with stock wheels!
    Dean_20's Avatar
    Oct 2006
    Middlesbrough
    65
    erm the tyres are standard size, think they are falcon or somethin, just got them to tie me other till i get my new wheels, probs done close to 1000 miles on them. the car itself has done 37k, iv had bearing problems in my previous car n it really does sound the same, but as iv bn told, it could be 1 of many things on the s3!
    rodenal's Avatar
    Oct 2006
    1,982
    if its really loud then a bearing should be fairly easy to check for if u have acess to a ramp.
    Stick it up, on the stands and spin each wheel, you should be able to hear it - there'll probably also be play from top to bottom on the relative wheel
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
