EM TuningSky Insurance
Results 1 to 15 of 15
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,836
    Cam/Rocker Cover Gasket
    Has anyone needed to get one of these changed on their 1.8T?
    After having my Cambelt changed last week, my mechanic has told me of a small oil leak coming from the Rocker cover gasket, it's nothing to worry about he says, but since the part is like 17, and it's free for me to get it done, I might aswell.
    It's leaking at the side where the cambelt is by the way, so you wouldn't notice it, unless the camcover was taken off!
    You've got to have a laugh!
    Erf
    Oct 2006
    Kingston
    230
    I was told i need to get a new one for my A3 1.8 Sport at the last service (back in january). John Ashley (VW) wanted 220 to fit it for me
    When I change the cambelt, i'll get it done at the same time. Need some money first though...just bought a house and made the mistake of proposing to my gf
    Can you let me know how long it takes so I can figure out how much it should REALLY cost me?
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,836
    £220? LOL! The part costs something like £17 from a motorfactor or 20+vat from Audi, they want 200 notes to fit the thing?!
    If I have my camera handy, I'll do a step by step guide, I know the coilpacks need removing and various engine covers, not sure if the inlet pipe needs to be disturbed though, but even that is 2 jubilee clips and 2 bolts.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    I really should look on here more often... mine was changed a few months ago by APS as it was leaking a very small amount of oil, was cheap (can't remember how much) to do and didn't take them long.
    Feb 2007
    Harrow
    221
    Anyone got a step by step guide on how to change the gasket? its looks striaght forward but be handy to have a guide
    Audi A3 54 plate 2.0 FSI Sport
    www.simplydents.co.uk
    Mods - 11 Rear lights, custom front matt black grille, I pod connection, S3 rear spoiler.
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    Take off engine cover panel
    Disconnect breather hose
    Disconnect earth cable
    Detach electrical connectors
    Unbolt ignition coils
    unclip tooth belt cover:
    it should look like this:
    Unscrew nuts and remove cylinder head cover:
    remove gaskets:
    Apply some sealant to transitions...on top of cylinder head
    replace head cover.
    starting with inner clinder head cover nuts...tighten these 3 first then move to the outer nuts tightening in a diagonal sequence.
    Inner nuts
    NOTE: TIGHTEN NUTS TO 10Nm. DO NOT OVER TIGHTEN
    reverse all removal procedure for other parts
    Hope this helps
    Feb 2007
    Harrow
    221
    Cheers thats looks very helpful!!
    Couple of questions: cant see where you put the coil packs, did u take take them out completley? or they hanging on the side?
    The sealant you mention? any particular type? How many transition points are there? only on one side?
    Feb 2007
    Harrow
    221
    Also i take it you dont have to take the spark plugs out ?
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    coil packs out completely...They are push fit
    No need to take spark plugs out
    sealant is a silicone based one or gasket sealant sealant from halfords
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,836
    Quote Originally Posted by abdus
    It's a bit more complex on an S3, need to undo the charge pipe, and on my APY engine, the coilpacks are screwed down, so you need to remove other little bits and bobs to get to these.
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    Quote Originally Posted by jojo
    well I was actually taking into account nik's signature (A3 1998 1.8T)
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,836
    Of course, I was just informing S3 owners the job in hand is a bit more complex, I didn't have my camera on me whilst doing mine, so many thanks for the writeup and pics.
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    What are the Transitions??..im doing my cover tomorrow and need to know where to put the instant gasket
    A3 1.8 TURBO| RS6 18INCH ALLOYS | FORGE 007 | SMOOTHED O/E BOX WITH COLD AIR FEED | COILOVERS | MOTECH RE-MAP | FULL CREAM LEATHER | FORGE DV RELOCATION | FORGE TIP HOSE|SILICONE BOOST HOSES|REMOVED REAR WIPER|G60 FLYWHEEL & VR6 CLUCTH|MILTEK CAT BACK DISCREET SYSTEM|312MM BRAKE UPGRADE|UPRATED DOG BONE MOUNT.
    Apr 2010
    Widnes Cheshire
    404
    I would think that the instant gasket goes on the mating surfaces or on just one mating surface.
    DC
    His: 2001 1.8T AUM. Hibiscus Red Pearl Effect - Hers: 2002 1.8T AUM. Metalic Silver.
