Chris NottAH Fabrications
Results 1 to 27 of 27
Thread: New Clutch
    recomdos's Avatar
    Feb 2004
    North East
    988
    Question New Clutch?
    Hi all,
    Noticed the clutch pedal was feeling odd yesterday. Today it was still feeling funny, and on the way home tonight I could only hear what I'd describe as a rattling screech, which was intermittent. No music on the way home, just the windows down listening out for the noise.
    So the clutch pedal is jerky. I parked up, released the clutch and the screeching was back, as soon as I dip the clutch it goes away - so I'm pretty much guessing it is the clutch bearing.
    Therefore, I was wondering if anyone has any ideas how much a new clutch kit (clutch + flywheel + pressure plate kit I'm lead to believe?) would cost. It's an 1998 A3 1.8T (AGU engine code) for those that don't know me. It has an AmD remap. The miles are creeping up now, and I knew it was a matter of time until I needed a new one. I'm not particularly looking to uprate the clutch as I've been happy with the OEM.
    By the state of teh sound, I think it's pretty obvious I need one ASAP, as I'm going to be off the road - which is a bugger!
    Thanks for any help / suggestions. Would there be any further tests I could do to fully check it is DEFINITELY the clutch?
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    £400 from GSF. Same as OEM. Make sure you get the slave cylinder changed at the same time.
    recomdos's Avatar
    Feb 2004
    North East
    988
    YEOUCH!! wasn't expecting that just for the parts! eeek. surely it can be sourced cheaper. no? :S
    (thanks anyway)
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Tell me about it - I'm still feeling bitter about it! The flywheel is the most expensive part. (then labour)
    nky_84's Avatar
    Oct 2005
    Edinburgh
    431
    why do u need a new flywheel if the clutch release bearing has gone?
    recomdos's Avatar
    Feb 2004
    North East
    988
    well I'm not entirely sure if it's the bearing. a friend who's a mechanic said it is likely to be that, but surely it's just worth replacing it all whilst it's off? plus because of the mileage, I thought it'd make sense.
    any other ways to test and make sure?
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    That seems an awful lot to me. I think an OE Sachs kit is more like £125 plus 4 hours or so labour to fit it; the uprated Sachs kits (just bought on on a GB with SeatCupra.net) is about £500.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Dec 2006
    N.Ireland
    369
    why replace the flywheel????????????
    recomdos's Avatar
    Feb 2004
    North East
    988
    Cheers Jason ,
    I'm a bit confused now actually. Do I NEED the flywheel, or is it just good practice to get it when putting the clutch in? Could anyone confirm the process?
    A clutch and flywheel kit does not sound cheap in any respects....then labour on top. Is the sachs group buy finished? I'd assume it is if you have yours?
    ta,
    batwad's Avatar
    Jul 2006
    Beds
    841
    With regards to the flywheel, it's down to the individual case. I recently had my clutch changed as an oil seal had failed so there was oil contamination that was causing the clutch to slip. The flywheel was absolutely fine, so no need to change it.
    I have heard reports though that badly worn clutches can damage the flywheel, but I think it's far from a matter of routine to replace the flywheel while the clutch is being done. Take the car to a good garage that know what they're doing and they'll be able to judge whether it needs changing or not.
    03 A3 (8L) TDi quattro Sport, Aluminium Silver with leather, armrest, cruise, xenons and me at the wheel
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    The only way I could tell that my Flywheel had gone was because it was rattling and then when you pressed the clutch a little it stopped. The guys that fitted the new kit confirmed it was knackered.
    recomdos's Avatar
    Feb 2004
    North East
    988
    Quote Originally Posted by Aky
    'kin great!
    Apr 2007
    297
    Audi and a specialist conf to me back in Feb that they chnage the dual mass flywheel (S3) 99.9% of the time. i dont know why though but seems like it needs to be done. I drove one that didnt have it done and the clutch did not work properly at all - had to take the pedal right to the floor and the gearbox felt like it was baulking.
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Quote Originally Posted by recomdos
    'kin great!
    Same symptons? Also my pedal dropped to the floor a few times aswell. No more F1 starts for me. I take it easy now - don't really trust it!
    recomdos's Avatar
    Feb 2004
    North East
    988
    yeah - same symptoms: the noise that is there until ya did the clutch. not had the pedal drop to the floor though, just felt 'jerky'. it's been quite sudden - no signs of wear, just in the past 2 days. grrr. I'm a pretty conservative driver really - never thrash it in 1st gear. I guess it's the age.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Unlucky geez, hope you get it sorted soon.
    I didn't need a flywheel, when my gearbox decided to exploded and take the clutch with it, so might be worth getting it looked at first?
    You've got to have a laugh!
    recomdos's Avatar
    Feb 2004
    North East
    988
    Hiya Jojo How are you?
    Thanks for the post. I'm planning on getting it looked at. Havin spoken to a mechanic friend at work it could be a number of things....shame he's not allowed to do any work on staff cars anymore
    Out of curiosity, can anyone confirm if it's a Dual Mass Flywheel?
    Ta,
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,067
    Quote Originally Posted by jojo
    haha, i did! the old final drive blew up at 60mph on the A31, sent planet gears into the gearbox casing itself, and into the bell housing destroying the flywheel!
    im fairly sure its a dual mass flywheel on both the A3 and the S3 isnt it?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Quote Originally Posted by Prawn
    Wasn't that funny when your transmission locks up at around 55mph on a damp M42, think my quick reactions saved me actually lol.
    Here's a pic of my gearbox, with metal shards all over the place!
    And here's a close up, you can see the diff!
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    You might be lucky on the GB - although it officially ended last Friday (20th). It is with JBS Autodesign in Chesterfield, and for upgraded Sachs items.http://www.seatcupra.net/forums/showthread.php?t=117446
    Jason
    Nel
    Apr 2004
    26
    hi I've been told that my flywheel needs replacing (s3,03 with 37k) but then another garage told me it was the gearbox.....how do I know which one's right? It's gonna cost £605 for clutch, flywheel and master slave, or £495 for a reconditioned gearbox.....what should I do? Any help would be greatly appreciated.... thanks
    daz2347's Avatar
    Jan 2007
    Berkshire
    81
    Quote Originally Posted by jcs356
    That seems an awful lot to me. I think an OE Sachs kit is more like 125 plus 4 hours or so labour to fit it; the uprated Sachs kits (just bought on on a GB with SeatCupra.net) is about 500.
    more like double that! mr clutch quote 7 hours Audi quote 8 hours and two other garages have quoted me 6-7 hours!
    Sex on tv is good Just dont fall off
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Quote Originally Posted by Nel
    hi I've been told that my flywheel needs replacing (s3,03 with 37k) but then another garage told me it was the gearbox.....how do I know which one's right? It's gonna cost 605 for clutch, flywheel and master slave, or 495 for a reconditioned gearbox.....what should I do? Any help would be greatly appreciated.... thanks
    Whats your symptons?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    I got a used box for 300, if the gearbox is coming out, you should really change the clutch also, as most of it is labour. I had my gearbox fitted along with a new clutch for 225 labour, I supplied the clutch which was around 160 and of course the gearbox.
    Nel
    Apr 2004
    26
    Unhappy
    Well the car sounds very diesel like when I start it and when its idling but when I press the clutch all the way down the noise stops, also if you put your foot on the clutch pedal it vibrates slightly. Sometimes the gears are not as smooth as they used to be (very rarely), its just mostly the noise.
    batwad's Avatar
    Jul 2006
    Beds
    841
    Quote Originally Posted by daz2347
    Shysters and rip-off merchants. VAGTech did my clutch in four hours. Anyone who tells you it can't be done is either crap or having you on.
  28. #27
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    If it rattles and vibrates the whole car it sounds like the same as mine - new flywheel is required. but might be worth getting the garage that said gearbox needs replacing to do that and if they are wrong make sure you get the flywheel done at their cost.
