Results 1 to 13 of 13
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    Squeaky Dashboard
    I have had my S3 now for about 3 weeks and have finally today decided to find the source of my interior squeak.
    I finally found it, if i grab the dashboard on the right hand side of the steering wheel it squeaks when moved and this happens over every bump and when driving slowly absolutely does my nut it.
    I can't tell what the dashboard is rubbing on exactly, it doesn't feel particularly loose or anything.
    Does anyone have any idea what I need to do ?
    cjhill's Avatar
    hmmmmm interesting.
    Aug 2005
    UK, South
    335
    the dash in that area is held on with about 4-5 screws, perhaps on of them is missing ( a previous owner being a cowboy??)
    Take the fuse cover off and have a look at the screw holes - see if any are missing, try tightening the ones that are there.
    There are also a couple of screws in the footwell if my memory is correct.
    If that fails you could always undo the whole side of the dash, put little pieces of sticky fabric between all the parts and put it back together again.... but that would be uber anal.
    Hope it helps.
    When it comes to rattles there is no quick fix, just patients.
    Call of Duty Zombie Slasher.
    rodenal's Avatar
    Oct 2006
    1,982
    or patience, if you dont wanna look after sick people all night
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    cjhill's Avatar
    hmmmmm interesting.
    Aug 2005
    UK, South
    335
    doh!
    Jun 2004
    Surrey
    595
    Is it the panel below steering wheel i.e. with light switch on, as this is what normally squeaks and rattles? Let me know if it is as I have detailed instructions from my guide.
    As previously said it is probably a loose or missing torx T20 bolts at end of dash.
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    I'll have to take it for a drive late rI have had the panel off a few times that you are talking about to change some sensors that are under there and there is one bolt missing which i will get round to replacing asap(I had forgotten about it trill you said)
    however it doesnt seem to be that it seems to be the dash, which today doesnt seem to be making any noise although it is warmer today and the dash will have expanded a bit making it a more snug fit, so later tonight when it cools down a bit I will see if what I have doen earlier has fixed the problem.
    Thanks James
    Jul 2005
    2,488
    black felt cloth.
    You must be able to get the sticky backed stuff from audi i would have thought.... they must get through it like bogroll at glastonbury.
    Jun 2004
    Surrey
    595
    Quote Originally Posted by madvw
    black felt cloth.
    Lol. I thought I was the only one with rattles.
    I have used a tape like this to solve some of mine. http://cgi.ebay.co.uk/Anti-rattle-fe...QQcmdZViewItem
    Jul 2005
    2,488
    thats the stuff, not had to use any on my current car.....yet.... used it on my old MK2, and It works really well though!!!
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    well i undid the nuts at the end of the dashboard pushed it up with one hand whilst re tightening with the other hand and it seems to have killed the squeak.
    Apr 2007
    Hazlemere, South Bucks
    63
    Can someone please tell me exactly where these dashboard bolts/nuts are as I will borrow a Torx key and tighten them up tomorrow afternoon.
    Also, how many are there?
    A bit of info before I start will be really helpful and save my poor back from bending like a Russian gymnast !
    Jun 2004
    Surrey
    595
    At end of dashboard when you open the door. Insert key in slot and twist then pull cover off there are 3 clips that hold it in place. You need a torx T20 driver to tighten.
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    I am sure i used a T25 torx bit.
