Volks AutosJMB Retrofits
    SilverBullet's Avatar
    Bullet
    Nov 2006
    Istanbul, Turkey
    11
    Exclamation Error: Voltage too Low ?
    VAG-COM gave a fault in engine
    18010 - Power Supply Terminal 30: Voltage to Low
    P1602 - 002 - Lower Limit Exceeded - Intermittent
    My battery is new, This error started after I completely painted my car including inside of hood.
    Engine works like cold and unstable, rpm in idle: 740 - 840 - 900
    What can it be anyone has an idea or experience?
    (2000 A3 1.8T AGU)
    SilverBullet
    dultanur's Avatar
    all promises, no action :)
    Sep 2006
    Istanbul,Turkey
    407
    2000 Black S3 (Sold, then totalled) - 2008 A3 1.4T Sport
    Mar 2005
    Swindon, UK
    48
    You say you have had the car painted including under the bonnet. I would check all the earthing points in the areas affected. Check you've not painted over earth points or got paint into the threads of earth points.
