Pull up the cap on the rear wiper. Underneath will be the jet on the bolt. Check that the jet is clear, pointing the correct way and not loose (on mine it came loose and the jet was pointing to the inside of the cap) and test again. Should no fluid come out then you may have a split pipe or a loose connection somewhere. To find this you would need to take off the boot lid lining and have a delve in; also would be worth looking in the engine and seeing if a leak may be happening around the washer bottle. Failing that could be a pressure loss or a split pipe along the car somewhere.
