EM TuningAH Fabrications
Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
  1. #41
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    ok measured to the sil mid way but the stronger part of the body that the sil fastens to and one side is 180 mm the other 190mm
    also measured from the centre of the wheel to the top of the wheel arch and they are from 360mm rear 370mm
    red to red black to black blue to bits
  3. #42
    spiker's Avatar
    usually growling at something
    Jul 2005
    Thornbury
    200
    assuming the ride height doesnt change then ?
    are you suggesting the ride height doesnt change without these ?
    i am confused - explain
    If you aint first you're last
  4. #43
    thats me
    Sep 2004
    west yorkshire
    3,762
    well mine is std appart from the R32 Arb so if yours is the same height then the rear adjustable bars are not needed ????
    is yours the same height as mine even though is suppose to have lowered springs on it then ???
  5. #44
    spiker's Avatar
    Jul 2005
    Thornbury
    200
    From memory the last time i checked after the mod - the middle of the sill to the ground approx 140mm
    cant find a bleeding tape measure right now as I am away but I will double check
  6. #45
    Sep 2006
    Sunny Suffolk
    554
    Spiker,
    Still happy with this setup? Did you / have you got adjustable tie-bars or uprated ARB's?
    ICE
  7. #46
    spiker's Avatar
    Jul 2005
    Thornbury
    200
    havent gotten around to making any other changes but VERY happy with the fsd's - it just makes the ride less harsh and still handles well
  8. #47
    Jul 2006
    sydney aus
    10
    someone mentioned h&R's
    Ive had H&Rs,KW, now FSD/Eibach
    The H&R's were terrible- knock your fillings out ( bad roads in sydney)
    KW leaked from day one ( not much , but even the replacement ones did)
    Koni- fantastic
