EM TuningSky Insurance
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    Unhappy Head gaskets going need advice....
    The cars at a local Audi/VW specialist in Dartford at the moment having a few problems fixed but its come to light that my head gasket is on its way out! I cant believe it Ive been told it could cost around 600-700 to repair!
    Is this a normal price? I said ill leave it for the time being and think about what to do. I really cant afford to fix it at the mo or for at least a few months. Will it be ok to leave that long?
    Also one other major problem is it was misfiring due to one of the sparkplugs getting burnt out, Ive replaced all 4 with the expensive NGK plugs but the garage said its a matter of time before one of the plugs gets burnt away again and it starts to misfire. Is there a way to fix this and is it expensive? Just dont want to have to keep replacing a plug every month or so.
    Any advice would be appreciated.
    Thanks guys
    Allan
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    how many miles has your car done??
    unfrtunatly 6-700 sounds about right from an audi dealer try and find an vw/audi specialist in you area should be cheaper, don't leave it too long though as water in the oil or vice versa can really damage your engine ruining coolant and lubrication.
    as for your misfiring could be due to oil getting through your headgasket to the cylinder, but i'm not sure. is it smoking alot when you drive it hard?? like burning oil.
    S3 - Gone but not forgotten!
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    hi, yes in the mornings its just pure white smoke coming out the back, cars on 80k.
    That price was quoted from a local audi/vw specialist guess i better shop around see who can do it cheapest for me.
    i better go find my credit card.....
    Dec 2006
    halifax, west yorks
    67
    it sounds like you are getting water in to the cylinders(white smoke), definitley a cause of your spark plug problem. the cheapest you will be looking at is in the region of 5-600, sorry!!!!!!!
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    k thx guys, will get it fixed asap
