Results 1 to 17 of 17
    MarkyB's Avatar
    Bristol & Salisbury
    106
    S3 Suspension - which shocks/dampers?
    Am in a bit of a dilemma.
    S3, ~6 years old (from new) with original (Audi Stock) shocks and Eibach Pro Kit lowering Springs (F)25mm (R)20mm. 26K miles on the clock (I work from home).
    Ride is now rather bouncy-castle, which is no fun when driving on Bristols appalling roads; pot holes, subsidence, sunken drain covers, patchwork quilt of tarmac over innumerable holes dug by the Gas, Elec, CableTV, Telephone and Water companies.
    I suspect that the ARBs need replacing and that the Audi Shocks are getting a bit tired after 6 years.
    Question is which shocks to go for? Bilstein Sprintline B8's are kinda pricey at ~400, but they do a Streetline Kit (shocks + springs) for 200; I could eBay the Eibach's for a couple of s to offset the cost.
    Will the Streetlines be up to the job of keeping my S3 on the road, or are they a false economy and I should spend the 's on the Sprintlines? Or are the Sprintlines going to be too harsh and require me to make a weekly appointment with a chiropractor?
    My car is strictly for getting from A to B in safety and comfort with the odd bit of fun on a country lane. Zero chance of me taking this car on a track
    Cheers,
    Mark.
    Blunteh's Avatar
    Mar 2006
    South East UK
    198
    I've seen Koni FSDs recommended for road use a fair bit Cost wise about half way between the 2....
    Nogaro Blue 2001 S3 - Revo Remap (Stage1) - Hyperboost DV - Neuspeed 22mm + 19mm ARBs
    Feb 2004
    2,036
    I would not skimp on the suspension compnents if I were you. If you fit them yourself its one thing,but otherwise the labour alone for fitting is as much as a cheap damper kit, so may as well fit as good a one as you can afford! Less chance of having to change it then later on!
    I will pick my car up with its billies B8s and HRs later today.....!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,582
    The Bilstein stuff isn't cheap, but they do the job, and will probably last forever...
    MarkyB's Avatar
    Bristol & Salisbury
    106
    Has anyone run Eibachs with the Bilstein B8's?
    I'm happy to spend the money if the ride is worth it, but I'm not looking for a track-hard setup with the bumpy roads I'm going to spend most of my time driving on.
    Cheers,
    Mark.
    Feb 2006
    Lincolnshire
    722
    Whilst I don't have an S3, I can thoroughly recommend the combination of Eibach sportline springs and Koni FSD's. They've transformed my car, and I look forward to bumpy roads and corners now!
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Mahonee
    Nov 2006
    121
    Think you'll find if you search on this topic the best shock and spring setup is clearly:
    Bilstein shocks with H&R springs.
    2001 Audi A4 1.8t - quite nice really
    Feb 2004
    2,036
    Have to say just on the springs front, H and Rs are just far better developed than Eibach versions, certainly on the Golf 4 variants. Tried both with the same dampers, its truly incredible how much better the -25mil H and R springs are to their equivalent Eibachs! They are springs FFS, but for some reason the H and R stuff just works better!
    If you shop about you can get the H and Rs for about £130.
    I got my Billies for £380+vat. So overall, whilst not exactly cheap, its not that much more than Koni FSDs and Eibachs...
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,582
    Quote Originally Posted by MarkyB
    Cheers,
    Mark.
    Yup, I have B8's with Eibach springs, but I fancy a change to H&R springs at some point, as I'm not happy with the way the car sits on the Eibach... it's like only 5-10mm lower up front, and I wanted a 20-25mm drop over standard!
    MarkyB's Avatar
    Bristol & Salisbury
    106
    Jojo, did you need adjustable tie-bars and/or a camber-kit to be able to set the tracking properly?
    Cheers,
    Mark.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,582
    Cheers,
    Mark.
    I haven't yet fitted the tie bars to adjust the rear camber, but running 19" wheels, I can see the increase in wear on the inner edges, and at 450 per set of tyres, I'm going to invest in the tiebars(I'va also considered the adjustable camber kits) at some point to save myself 's in the long run...
    I will probably get the H&R springs done at the same time, just a matter of finding time and money to do it at the end of the day, as it's become more of a weekend project than a daily driver of late.
    MarkyB's Avatar
    Bristol & Salisbury
    106
    OK Guys, the best deal I kind find on Bilsteins is the B12 kit for ~485 which includes H&R Springs (yay!), does anyone know if that kit is B8's???
    Cheers,
    Mark.
    jesters3's Avatar
    The Shire's
    1,516
    Looking at doing the same thing. Currently booked in at APS for the ARB and springs and now just discussing dampers. Ess Three summed up the points very well have a read as it may assist.
    APS - remap
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    MarkyB's Avatar
    Bristol & Salisbury
    106
    Looks like I'm leaning towards the B8's and some Powerflex Bushes. Am fretting over the adjustable tie-bars :-|
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    B8's, H&R springs, and tiebars are what you need. I never liked the way the car handled when it was just lowered as it was too twitchy without the tiebars. The powerflex bushes are nice to have but they'd be a lower priority for me.
    [/sarcasm]
    Feb 2004
    2,036
    I t5hink the B8 dampers are what you need the B12s are for std ride heights I think...?
    B 8s have shortened piston rods and suitable for shorter springs.
    MarkyB's Avatar
    Bristol & Salisbury
    106
    Thanks for the input guys, much appreciated.
    I'll be dusting off my credit card in a couple of weeks for a set of B8's, Powerflex Bushes and adjustable tie-bars; I already have a set of Eibach Springs. Hopefully the improved ride will distract me from the sense of impending dread when when credit-card bill arrives
    Cheers,
    Mark.
