Volks AutosSky Insurance
    Mahonee
    Nov 2006
    121
    Just serviced the 'brief' !
    Right,
    popped the engine cover off to change the spark plugs for the first time since I've owned the car and I have never seen such a Duff design in my life !
    Two of the coil packs are located under a bracket that seems to have all sorts of boost hoses and electrics attatched to it. Amajor design flaw to cover the spark plugs that get changed so often.
    Anyway, I was hoping someone could explain the 'trick' to getting to these coil packs so as I don't need to start taking everything attatched to the bracket off. Is there some way of moving the bracket or something that will allow me access to the coil packs ?
    Also, I assume you need to unplug the wire from the coil packs to get them out (if that makes sense)
    cheers,
    G.
    2001 Audi A4 1.8t - quite nice really
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    I think there is just one stud holding the bracket on then all the pipes will move with the bracket to let you do the spark pluggs
    red to red black to black blue to bits
    Mahonee
    Nov 2006
    121
    done !
    Yeah, It was a bit of a fiddle but not to bad.
    if audi had just given a couple more mm here and there, servicing would be so simple.
    Anyway, just finished my first service of my S3 and the result : No Problem.
    I seriously suggest everyone who has an 8L service the car themselves. I bought only the best of gear and the total for:
    4xNGK platinum plugs
    1x4L Castrol RS 5W30 semi synthetic oil
    oil filter
    K+N element cleaner
    1xpack of Bosch Aero wiper conversion kit
    and to quickly check the brake linings
    was 95 and took about an hour in total
    saving: A LOT ! !
    P.S just for reference:
    Spark plug torque setting: 30Nm
    coil pack bolts: 10Nm
    aero wiper part no. AR533S
    NGK part no. PFR6Q
    And a wee thanks to 'RichA3turbo' the pump for the oil was magic !
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I fully agree, I do all my own servicing, I recently bought:
    Oil Filter
    Fuel Filter
    Pollen Filter
    4x Spark plugs
    5L Synta Gold
    Aero Wipers
    For £61 +VAT from GSF, Used my Club GTI discount and got 10% off.
    No reason to go anywhere near a garage.
    <Insert meaningless geeky specs here>
    Feb 2004
    2,036
    Are your aero wipers just the replacement blades? do they fit stock arms?
    Anyone got one of those activated charcoal pollen filters that bosch apparently do> Have to say I like the idea of one of them, espeically in town!
