Badger5Monster Motorsport
Results 1 to 21 of 21
    Feb 2007
    102
    car hesitating/holding back
    having a few probs with the new motor (A3 1.8T quattro)
    when you put your foot down, usually in 3rd n 4th gear at about 3/k rpm the car hesitates/holds back (feels like its going slower) then once you get past 4k rpm it clears and goes again
    any ideas what this could be?
    Air mass meter? heard they can cause probs?
    99 A3 petrol turbo - Quattro
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    collapsing hoses on the TIP?
    ...have you upgraded to samco or alike or are you using OEM?
    S3(225) - Dolpin Grey | Leather/Silver Alcantara | Bose | ViperDV | Samco Hoses | Eibach Pro-Kit | H&R Spacers | Brembo GT kit | AreoWipers | BlueTooth | Dension Icelink | New engine, Clutch, Turbo, Water pump thanks to Cambelt @ 79,000 miles | New short engine thanks to ****ed valve 22,000 miles later!
    Dec 2006
    44
    I had, well have the same problem, i changed the standard dump valve and cleared the fault and it was boosting fine, but after a week or so same thing? So you could always try changing the dump valve first.
    Dec 2006
    N.Ireland
    369
    have a read of this thread.. your not alone
    http://www.seatcupra.net/forums/showthread.php?t=112856
    Feb 2007
    102
    MCD - no its on std hose's, is there anyway to check the hoses? as i dont think i can check them to see if there collapsing at 80mph lol
    k17rpo - i haven't got a dump valve on it
    cheers for that claude, just had a read seems like a lot of people are suffering from this, although they dont really have an solution to the problem, are the leons n cupras engines the same as the audi?
    anyone else shed any light on this?
    adamgroves's Avatar
    Jun 2004
    North Yorks - Northallerton
    59
    I have a similar problem. I had the dump valve replaced last week as it was reporting a boost valve problem. The car seemed to be boosting a lot better at first, but its been hesitating on and off then i got a engine fault light come on the other day. Plugged in the vagcom and it said that it had detected a pressure drop between the turbo and the DV... or something along those lines. I reset the fault and the car seemed to be running really rough for about 5 minutes, the engine was knocking but then it sorted itself out.
    2001 Audi A3 1.8TQ Black
    Dec 2006
    N.Ireland
    369
    Quote Originally Posted by cawood
    very very similar engine.. the early Leon Cupra R had 210bhp and the later Cupra R had the 225 engine.
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    try your coilpacks, i had the same problem on mine. if not could be spark plugs, or MAF sensor.
    buy one coilpack and fit it to cylinder 1 and test, and work your way along the 4 cylinders. that way you can eliminate each cylinder
    hope this helps
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    Dec 2006
    44
    Mate they all have dump valves be it standard or aftermarket.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    [QUOTE=cawood]MCD - no its on std hose's, is there anyway to check the hoses? as i dont think i can check them to see if there collapsing at 80mph lol
    no easy way of checking....used to happen to mine, so I just upgraded - no problems since.
    you can insert a piece of piping as i recall to strengthen the pipe and stop it collapsing..there is a thread here somewhere???
    Dec 2006
    N.Ireland
    369
    I bought a forge hose to see if its this happening, will try get it fitted next weekend to see if that helps, however I cannot see it being the problem, only because it happens in 4th 5th and 6th... all gears will be flowing the same amount of air, be it 3rd gear at 6k rpm, or 4th gear at 6k rpm
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Quote Originally Posted by claudefrog
    ...but it depends on how hard your PUSHING the car, or how hard its working.
    Therefore 1/2/3 relies less on torque, and therefor doesnt suck as hard. 4/5/6 the car has to work harder and therefor requires more air. Hence hose collapses.......
    ........or so I understand it.
    ..................ready to be shot down if my basic explanation holds no water.
    Sep 2006
    Sunny Suffolk
    552
    Did anyone ever get to the bottom of this? I think I might have expereinced it on the way home today.
    Was at about 5000 rpm in 3rd (possibly 4th) the car seemed to hold back then after about 1 second it picked up again. My initial thought was collapsong OEM TIP, but I'm no expert.
    ICE
    Jun 2006
    298
    Quote Originally Posted by vanilla_ice
    ICE
    I'll put a grand on the MAF.
    Mine does this, and I've had new sensors etc. Maf's about 14 months old though.
    Sep 2006
    Sunny Suffolk
    552
    Thanks for the quick response!
    Do you mean new uinit or clean the current one?
    Cheers,
    ICE
    Jun 2006
    298
    You can try cleaning the current one, with some electrical contact cleaner, but it'll only put the problem off. Ultimate solution is a new MAF unfortunately.
    I can predict the point at which it happens and will factor it in to my driving, overtaking for example!!
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    947
    Could even be plug gap too big,thats what mine was,but mine was popping and banging mid range misfires.Ok when slowly built up to speed ,just under full load it misfired.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    Can I Borrow 1.4 Bhp off anyone please
    Nov 2006
    Wales
    72
    my cars doing this and its annoying the crap outta me.......and i still havent got to the bottom of what it could be, no vag errors mapped either. I'm keeping an eye to try and find out. It appears to have got worse since the car was in the garage for a new waterpump and timing belt, some people say its the temperature sensor but i dont see how
    A3 1.8T quattro Sport - Stainless Exhaust with Sports Cat- Tints - AMD Tuned 198.6 bhp, 217.4 ft/lb - Pretty Red Calipers
    Dec 2006
    84
    timing belt out a tooth? if it started right after the belt was done. I wopuld check this first of all, then i'd check the coolant temp sensor.
    Nov 2004
    103
    I had similar problems with my '03 S3. Read many many threads like this. I only noticed the hesitation (like a misfire) sometime after having a Revo remap. I tried the following
    (no vag-com codes to assist either)
    New MAF - seemed to be better for a few hours then back to normal
    New DV's
    New N75J - made car a bit more lively
    New Temp Sensor
    One thing I did notice was that disconnecting the battery to reset the ECU seemed to really liven the car up a bit for a while then it sort of fell back into its normal way of running - wonder if that was something to do with lambda's and the car learning and cutting back after a while.
    At 40K it wasnt ready for service yet so I replaced the plugs myself (good instructions on here somewhere)
    New plugs seemed to improve things but then the car seemed to get rougher then a coil pack went which needed replacing.
    Now, i'd read all about coil packs and my model was supposed to have the non-faulty ones on but they did start to fail and only noticeable when it finally give up. Maybe worth a try replacing one or all. If I still had my 8L S3 with the problem I reckon it'd be worth replacing if you'd tried everything else (it'd done 40K). They're at revision R or something now.
    Jan 2005
    Ashford, Kent, England
    15
    RGS3, if disconnecting the battery helps to 'liven' the car up, could it not be a problem related with your throttle body?
