Chris NottMonster Motorsport
Results 1 to 17 of 17
    Oct 2005
    England
    101
    Vag Tacho Help Please?
    Hey guys just a simple quick question. I have just brought vag tacho from ebay.
    Unfortunitly the cd that came in the mail is damaged. I downloaded the software version 1.9 online but i despiratrely need the drivers for 1.9
    If anyone has vag tacho drivers for 1.9 and is willing to share them with me it would be greatly appreciated.
    KEF A3 20V T's Avatar
    Turbo's Rule
    Sep 2006
    Whitby
    198
    hi mate, i have the cable drivers for the vagtacho cable, if you give me your email address i will send them. they work with vagtacho 1.5 so i guess they will work with 1.9. there in a .rar file so u will need winrar to open it. p.s where did you download the 1.9 software n was it free? wouldnt mind upgrading mine to 1.9!
    Oct 2005
    England
    101
    Vag tacho 1.9 can be downloaded from vag tacho's web site.
    I too have 1.5 drivers ........ unfortunitly they are different.
    So if anyone has 1.9 drivers we both could do with them
    thanks
    Turbo's Rule
    Sep 2006
    Whitby
    198
    u got a link to the website mate? i will have a go at getting 1.9 to work
    Sep 2005
    Worksop, Notts
    97
    I used to have Vagtacho working on my old HP laptop, but I'm really struggling to reinstall it onto my new laptop. I have tried three laptops now (Dell Latitude D620, Sony Vaio VGN-A517S and an old Dell Latitude LS) and I just can't get the drivers working. I believe it's version 1.5 I should be using but I can't install the drivers.
    I'm actually a computer engineer and I'm annoyed I couldn't get to the bottom of this myself, does anyone have any ideas?
    s3ollie's Avatar
    Jan 2007
    749
    what can you use vag tacho for? searched the web but cant find much info.
    Apr 2007
    9
    hi,
    I have downloaded the software from tek-tronick.co.uk
    I have a VAG.COM cable, will this work with the VAG.TACHO software, or do i need a different cable?
    Any help appreciated !
    Sep 2005
    Worksop, Notts
    97
    Quote Originally Posted by s3ollie
    It's use is to download and upload the dashboard EEPROM via the OBD port. It has various functions one of which is to change the dashboard functionality on Mk4 Golfs and Boras (you can change the needle/gauge illumination and add miles to next fillup etc) and another one is to change the displayed odometer reading.
    I'm pretty sure it won't work with a Vag-Com lead if it's an official Ross-Tech one, but if it's a third party/ebay job it might work.
    Apr 2007
    9
    Apr 2007
    9
    Well i bought a Vag Tacho cable.
    I have a 2002 S3, but i cannot get it to work properly.
    When i select " connect any ECU" i get -
    So i tried connecting to "VDO new", but it said not found, eventually after a few it connected to Audi Immo Box.
    When in the above screen i then click " get pin", but i then get a message saying, Error,or access denied.
    Iam using version 1.5.
    Any ideas please? am i connected to the correct ECU? i thought i saw somewhere that the A3 upto 2002 used the "Magnetti Marelli M73".
    Cheers guys.
    Aug 2003
    Spain
    66
    Vagtacho 1.5 only works with A3/S3's up to 2000. New VDO dashes implement a checksum check. You need vagdashcom, but it's pricey, 500€.
    Audi A3 S3
    Apr 2007
    9
    So can i not get my pin atall?
    When i was sold the cable it said audi's upto 2002, which mine is ?
    I have v 1.1 to 1.8, none appear to work..
    Any help much appreciated!!
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    How much was your cable? Cheapest I've found was £40, which is a lot of money compared to vag-com. Or does the vag-tach cable double up as vag-com too?
    <Insert meaningless geeky specs here>
    Turbo's Rule
    Sep 2006
    Whitby
    198
    you can get serial cables that double as a vag com and vag tacho lead. but like you say they are bout 40 to 50 quid.
    they are a good bit of kit tho. get a few ppls skc codes for them and it pays for its self.
    Feb 2009
    Hi guys i got some promblem whit my vag tacho 2.5 . Last time i tried to use it whit ver. 2.6 and now it does not work any more. If i try to install it again i gor messege "usb to iso interface" found and not K-line..
    whould be greatful if you coud helm me.
    Jun 2009
    Quote Originally Posted by B-ome View Post
    +1 same problem help me please.
    May 2006
    Surrey
    175
    Is this true that Vag tacho only works on car up to 2000 year? I brought from this site: http://www.vagproducts.co.uk/vagtacho.html after finding a reccomendation on this forum. I have a 2001 audi s3 and the website says it works on car up untill 2002 but I can't get it to fully connect to my ECU?
    Any help please?
    Audi S3 2001. Black on Black. OE Sat Nav/Freeview. Bose. 18" Audi/BBS Splits. 10+16mm Spacers. KW Coilovers. Forge DV,tip and intercooler pipes. KnN Panel Filter. Oh and the essential Re-map. GONE
