Volks AutosJMB Retrofits
Results 1 to 14 of 14
    Booth_S4's Avatar
    Riding on V8 power
    Oct 2006
    Newcastle, Staffs
    657
    Thumbs down Not happy, possible petrol line crack/split!!!!!
    My car has been funny on start up for the last few days. I noticed the smell of petrol when i was getting in and out of car, then on start up it wasnt firing up on the first occassion. I am having to re-turn the key for a second time and it fires up no problem.
    Now ive found some petrol on my driveway, so either the petrol line is split or its the petrol tank.
    Anyone had anything like this happen before? How much is it likely to cost to rectify?
    thanks
    German iz ze vay forvard!
    Made with vorspung durch tecnik
    2003 Noggy S4 Avant - 344bhp of pure V8 muscle
    Feb 2007
    14
    It could just be your fuel filter. If the leak is coming from the drivers side near the rear quarter near the tank then it might just be that. Apparently they're prone to rubbing on the tank and putting a hole in themselves. I got to work one morning and found a puddle slowly forming under my car. I got it recovered to a garage who charged me 32 for parts and labour to fit a new filter
    I was quite relieved!
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    My S3 had a split in it's fuel filter as well...
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Blimey that sounds like a serious fault!
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    If it is the fuel filter, consider changing it yourself.
    It's around £4-6 and takes approx 5-10 minutes to fit..
    <Insert meaningless geeky specs here>
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Might want to depressurise the fuel system first or get a face full of fuel at 60psi
    Chris
    See my images @
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Unless the engine is on and running the fuel filter is not under pressure.
    I've changed enough, it kinda dribbles out. Mind it does hold a suprising amount of fuel considering its size.
    You need to clamp off the pipes and swap it out. really simple.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Must be different on the Audi then, the last fuel filter I changed was well after the engine was shut off, and the fuel line was still pressurised.
    Chris
    See my images @
    Dec 2006
    N.Ireland
    369
    i agree with A4Quattro
    the s3 lines are still pressurised when changing a fuel filter.. and TT is the same also
    I have recently changed both an S3 filter and the TT filter, both let out a woosh as i disconnected the filter, under pressure
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    I would say it depends how long the engine has been turned off as the pressure will bleed away. Thats why the pump primes itself (to pressurise the system) when you turn the ignition on.
    If left overnight you should be fine but take precautions anyway, I.e Wear protective eyewear and something to soak up the fuel should you spill/spray any.
    Rarrrr! I'm not Lesdyxic!
    There are three kinds of people in the world, those who can count, and those who can't.
    Clicky Here!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    On the subject of fuel filters, how often should they be replaced?
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Mine fuel filter wasn't under pressure after approximately ten minutes (oil change time) after switching the engine off.
    Same goes for my friends Mk4 and my girlfriends car too.
    Have other people ACTUALLY observed it being under pressure when replacing it?
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Yes I have had a face full of petrol spray out and into my eyes, not pleasant
    Chris
    See my images @
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    If you clamp the lines, as per ELSA, then you wouldn't see this pressure issue I wouldn't imagine, hence why i have had no problems...
