Chris NottBadger5
Thread: Xenon Problem
    May 2006
    Lancs
    211
    Xenon Problem
    The other day when I started the car up the warning light flashed up saying the dipped headlight/rear light had failed. However, all appeared to be normal when I restarted the car so thought nothing of it.
    Now though the passenger side dipped light is a fair bit dimmer than the drivers, but its still illuminated. Any ideas what has caused this? I would have thought if the bulb had failed it just wouldn't work at all.
    rodenal's Avatar
    Oct 2006
    1,982
    I had this a while ago and it was just the wiring had came a little loose, i'd check that first
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    May 2006
    Lancs
    211
    Thanks, only noticed it tonight so I'll check it out in the light tomorrow. Fingers crossed.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Seems to happen to mine approx. once every 2 years, in the cold... basically, on of the xenon bulb fails to light up, and you get the warning, but switch them off and back on, and it usually just flicks back on, so nothing to worry about imo.
