Hello Guys
Well the worst thing happened the other day, my water pump siezed/colapsed and took with it the timing belt!
In the shop at present getting re-built!
Questions are these:
1. Been told the cost will be around £1800 worst case, does this sound about right?
2. New valves, belt, tensioners, pump the usual! Whats the chances of the pistons, cam shaft, crank shaft, turbo being damaged?
3. Is there a chance that this repair will not be perminant and i can expect lots of problems now, the car was great until this 2001 W reg 52K miles. Should I get the work done and then sell the car?
4. Will there be a running in period once the work is done?
Mechanic (Audi specialist) telling me that no damage to the above items occur in his experience, although slight marking to pistons sometimes but nothing to worry about...
As always your help and advise is always appreicated.
Kindest Regards
Geoff W
Kindest Regards
Geoff W
