Badger5Sky Insurance
    Feb 2007
    South West
    153
    Brembo Questions
    Ok i have just got some Seat leon Cupra R calipers
    Unfortunatly i have no Brackets with them so am thinking of getting a local engineering shop to make me some up
    323mm x 28mm With 5x100Pcd is the standard LCR sizes
    can i Change the Spec on my Brackets to Give me different Disc options
    323mm x 28mm = 300+ discs n pads
    330mm x 28mm = 200 Discs n pads (VW R32 golf and Pheaton Disc's)
    305mm x 28mm = 200 Discs n pads (Porsche rotors but would need some custom Bells) With Audi RS2 Brackets
    any thoughts?
    Also if anyone has a set of GT Brackets the can take some measurements of Please
    Failing that if any body has some brackets they fancy selling let me know
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    FYI, the R32 disks are 334mmx32mm...
    I currently have an R32 setup and have just bought some 996TT calipers. I will be purchasing some LCR brackets to see if I can fit the 996 calipers to the R32 disks.. If they don't I will purchase some brackets from MBT engineering in Germany who will drill their semi-universal brackets to your spec..
    I believe the hole spacing is the same on the 996 caliper and the LCR brackets (130mm) it's whether the hub spacing will be suitable for the R32 disks...
    Rarrrr! I'm not Lesdyxic!
    There are three kinds of people in the world, those who can count, and those who can't.
    Clicky Here!
    craig_007's Avatar
    Sep 2006
    48
    I have MBT unmachined brackets that I don't need if anyone is interested
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    Craig you have PM
    Clicky Here!
