All of a sudden my traction control lamp has started coming on and staying on. It doesnt do it every journey mind but Im wondering if its a common fault? My mate has vag com but his laptop is bust at the mo so cant connect it up for a while yet
will find out this week, my mate had his lappy fixed so plugging vag com into it. Praying its nothing major, road tax due and just had cam belt changed so a bit skint
At the risk of sounding repetitive, please do a search, I myself covered this in depth...
It is more than likely the lateral acceleration sensor (G200), quite a common fault that appears sooner or later on a lot of S3's and Golf 4-Motions...
If your car is pre-facelift then you have 2 sensors, the lateral acceleration sensor (cheaper one) and longitudinal sensor behind the glovebox (expensive one).
Later cars have a combi sensor mounted under the steering column.
