JMB RetrofitsChris Nott
Thread: clutch slip?
    May 2004
    170
    clutch slip?
    Had my map turned back on there a few weeks back as the previoous owner had it switched off. Whilst I am very happy with there appears to be a sreechy noise only under acceleration normally when at 60-70 and accelerating to overtake.
    Im guessing its the clutch slipping as it doesnt do it without the map.
    Has anyone experienced this before??
    Its an S3 by the way
    MattS3's Avatar
    Jul 2005
    North Norfolk
    531
    Are you sure its not the turbo whilstling due to it working harder ?
    If the clutch was slipping, you see (and hear) the revs rising, but you'd not be accelerating as quickly as you should ?
    Best way to tell is to pick 4th gear at 40mph and then press the accelerator to the floor. Because the load is greater, you'll find the revs may rise, but the speedo doesn't, in which case it is a slipping clutch.
    2011 S3 Sportback S-tronic Black Edition - Revo stage 1
    2006 Mazda MX5 2.0 Sport - For track days and sunny days.
    2003 S4 V8 Saloon Manual Milltek Cat Back - Sold
    May 2004
    170
    ill check it out later cheers
