Badger5Monster Motorsport
Results 1 to 7 of 7
    Bellic's Avatar
    Dec 2006
    253
    software coding central locking vag com
    hi i was playing with the vag com yesterday setting the auto lock on doors
    in 35 cent locks , but my remote has stopped working , i had jotted the original software coding down but have misplaced it might be that not making my remote inoperative,
    anyone know what the original software coding is 35 central locking
    the car is 2000 a3 1.8t q
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Try 13130; add 32 to that for the auto lock doors as well.
    Regards,
    Rob.
    Bellic's Avatar
    Dec 2006
    253
    ok will give that a try , do you just add the numbers to the end of the soft coding , how many can you add what if i want honk on arm and auto lock?
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    16162 would be the code for the default options plus auto-lock doors; I'm not sure off the top of my head what the number is you add to have the horn/beep when you lock (and/or unlock) - there's a little program floating around somewhere that generates the correct codes from a tickbox selection but I'm stuffed if I can find a copy of it. Perhaps someone else might have a link. I think it was actually made for the TT but of course works with A/S3...
    Regards,
    Rob.
    Bellic's Avatar
    Dec 2006
    253
    yes i have that program i used the codes for the autlock , i put these in 35 cent lock then in recode then deleted the soft code , i tried adaption but the other channels were showing error message except channel 1.
    KEF A3 20V T's Avatar
    Turbo's Rule
    Sep 2006
    Whitby
    198
    If you key doesnt work you mite need to perform this operation:
    http://www.ross-tech.com/vag-com/car...-matching.html
    Here the program for the different soft codings:
    http://www.wak-tt.com/vagcom/vagcomclcoding.htm
    your start base code will be 13130.
    hope this is of some use to you.
    Kef
    Bellic's Avatar
    Dec 2006
    253
    ok cheers will try this tmw
