Monster MotorsportEM Tuning
    Jan 2007
    198
    Remote Key frequency??
    All,
    Got a 2000 A3QTS and only have the one real key and the black plastic one. The key I have is a 2-button key.
    What should I look for on Fleabay?
    Which frequency? / Code no.?
    Will a 3-button key work if reprogrammed?
    I know there was a post not-so-long-ago about reprogramming the fob with a sequence of window, down, window up, turn key, press button.....well almost. Anyone know the real sequence?
    Jas
    Jan 2007
    198
    anyone???
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    open your key up mate, stick a small slotted screwdriver under the tab thing and it will prise open, inside you will see lots of very small writing on the transponder bit, your part number and frequency will be on there, just search ebay for the part number.
    2 buttons are quite rare thou and im looking for one atm too!
    Hope this helps
    ash
    2001 Audi S3 l MTM Remap l 252.7bhp 432.4Nm l Forge 007P l ECS Porsche Stage 2v2 Front Brake Set-up l ECS Stage 1 Rear Brake Set-up l 18" RS4 Alloy Wheels
    KEF A3 20V T's Avatar
    Turbo's Rule
    Sep 2006
    Whitby
    198
    here is a link to the way to program your remote using keys:
    remote keys
    This is the way using Vag com:
    http://www.ross-tech.com/vag-com/car...-matching.html
