EM TuningSky Insurance
Results 1 to 8 of 8
Thread: Door Panels!?
    Feb 2007
    10
    Door Panels!?
    Hey guys!!
    My A3 8L!
    how do i remove door panel?? Here are some pictures of the screws i found. However still cant seem to pull anything off
    Can someone please tell me how i could remove the door panel??
    Jun 2004
    lincolnshire
    395
    i think theres one behind the door handle, if there isnt then i think its a case of pulling up to get it off. ive had mine on and off a few times.
    why didnt i take the blue pill......
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    There are some instructions on door panel removal at the start of this guide (which then goes on to explain how to fix the problems with knackered electric windows)
    http://www.piglet-net.net/tech/cars/a3-window.html
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Feb 2007
    10
    Thanks for your replies guys but:
    "Remove the screw under the door pull (circled, but not clear in my photo), pull out the cover, and remove the 2 screws underneath. The door card will now lift upwards and off. Watch out for the cables."
    I removed the door pull but there are no screws underneath, here i uploaded a pic of the door pull removed but cant find any screws inside/behind it!
    Feb 2007
    10
    anyone??plz??
    HOUCH's Avatar
    Aug 2006
    88
    Have you removed the 2 small screws at the top of the panel on the inside edges of the door ? If yes be brave and quick tug up and away from door and the panel should lift off no problem?!? Good luck should'nt put up that much of a fight.
    Houch
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    Yep, you need to pull upwards and away from the door.
    Jason
    Jun 2003
    World of my own
    9,813
    First lower the window, then the 2 main screws are behind the plastic "cuff" inside the grab handle (not the grab handle itself). This cuff is held in place by a single screw. Remove this then push down on the cuff and reveal the 2 main screws. With these out pull hard upwards and then out. This is difficult to do with the window up.
