Results 1 to 8 of 8
    Northern monkey
    168
    Coil Pack gone ???
    What are the symptoms when a coil pack go's??
    what does the car feel like to drive ???
    cheers
    matt
    Bucks
    1,038
    Re: Coil Pack gone ???
    I think it differs. Mine, car felt like it hit something while i was accelerating, engine mgmt light came on (the orange one that isn't in the handbook), and the engine stutters and misses.
    If you try to put your foot down at all (not hard), it feels like there's a blockage somewhere.
    Northern monkey
    168
    When the car was cold it felt ok, then as it warmed up a bit it felt like it was missing on one cyilinder just as i accelerated then got worse and is just lumpy now - no performance whatsoever ???
    Northern monkey
    168
    But ive had no warning lights come on ???
    any other suggestions what could cause this - its deffo not the clutch / MAF / or dump valve. ??????
    Bucks
    1,038
    First time mine went, it performed badly for a little while, as if it was missing, before anything drastic happened....
    Northern monkey
    168
    Right this is doing my head in now - went out in it last night and it didnt miss a beat, spot on. started it this morn drove half way to work and then it started poping and missing ?? could this be a dodgy tank of fuel / water contaminated ??? spark plug ???
    H E L P !!!!!!!!!!!!
    Bucks
    1,038
    Maybe spark plug?
    Northern monkey
    168
    Am now thinking it could be a temp sensor ??
    as it only started goin wrong half way to work once it was
    warm.. and it ran fine last night when it was pretty cold outside ???
    any suggestions ??
    Admin - if you think i would get more responce in another
    section ie technical - please move !!
    cheers
    matt
