AH FabricationsJMB Retrofits
    Jan 2007
    58
    2 strange problems with s3..help..
    firstly, my window washer container is leaking i think..it seems to empty quickly and there is water at the bottom of the bumper beneath the container....common problem?how do i fix ?thort maybey id check to c if it was a simple repair before i start stripping it to have a closer look.also there is a very strange sqwelching noise coming from engine when idleing, sounds like its coming from passenger side by the footwell.any idea's?
    spuddie007's Avatar
    Thomas the Tank Engine - Choo, Choo!
    Feb 2005
    Barnet, Hertfordshire
    210
    Could be the pipe at the front of the engine that taks the screenwash to the back of the car (and to the front washers)
    You could locate it by looking for water piddling just behind the front passenger tyre. Under the air box, there's a 'trunking' that's clipped together by a cable tie (the trunking runs from the front of the bulkhead towards the battery).
    You would need to remove the airbox and see if the pipe in the trunking is leaking? I've had this one, and the pipes simply pushed together, although I added some silicone to ensure a tight and permanent fit.
    Not sure about the bottle though
    Was an Audi S3, Pre-Facelift 210 bhp, Security Tints, Standard spec, simple sweet and to the point.
    Currently a Golf GT TDi 170 DSG in Pearlescent Black with every conceivable extra available - company car
    From June 2011 - Audi A3 Sportback Black Edition 140 tdi (company car) with DSG gearbox, Technology Pack + AMI, Storage Pack, Open Sky Roof System, Comfort Pack, Luggage Pack and Interior Light pack. Oh and it's Monza Silver. Can't wait
    larsmate's Avatar
    Apr 2004
    114
    Quote Originally Posted by jarvis**turbo**
    Common problem. It's either the xenon or window washer pump leaking. You'll need to replace one or both of them.
    Black S3 | MY09 | APR 3.4 Stage 2+ | RNS-E LED | Tints | 19" OEM RS3 Rotors | APR DP | APR HPFP | WALK | Bilstein B14 Coilovers | Lamin-X | Ashtray delete | P3 Gauges integrated boost gauge | BlueVAG VAG-Check |
