    nick1973's Avatar
    Nov 2006
    97
    a3 leaking water into car ?? any ideas
    my a3 is letting water int the car around the centre console cant be the heater matris as car is not lossing any water have lifted the plastic schuttle but can se naything wrong my guess is a grommet or something near the middle of the car under the scuttle any ideas
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    If I were you, take the wipers off, remove the plastic scuttle and completely clean out the drain holes down into the wings. I was getting a leak around one of the cable gromets because the drain hole was partly blocked resulting in the gromets being permanently immersed in water.
    This whole area of the car is very badly designed. You would think that Audi would have worked out that people might park their cars outside and as a result leaves and other bits of debris are likely to get into the scuttle area and cause water to stand in the tray.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Jun 2003
    World of my own
    9,813
    Yes drain holes bunged up is the most likely cause. This causes rain water to overflow and find it's way into the cabin. Even if there is no sign of water under the wiper scuttle, it would eventually have drained away after it's overflowed into the cabin. I had to remove 4 litres of water from under my carpets recently, took all bloody day as the foam is not protected so just soaks it all up before you even know you've got a problem.
    You'll need a special tool to remove the wiper arms:
    http://www.machinemart.co.uk/shop/se...per+arm/page/1
